Question about Microwave Ovens
I am looking for the fitting instructions for a delonghi ghs265st gas burner
I am looking for a Delonghi P90d25 25L 900W Standard Stainless Steel Microwave manual
http://www.delonghi.com/en-us/customer-service/instruction-manuals
Go to the above website. It shows you the information you need to enter and you will have access to the manuals. They want the product number.
Good luck.
Semper Fi,
Z
Apr 26, 2017 | DeLonghi Microwave Ovens
Re DeLonghi stove top - DEGH60ST/CON PLU 220230 We wish to obtain jets for the use of bottled gas with our DeLonghi stove. Also Does this model have a rubber/neoprene seal that isolated the edge of...
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Feb 27, 2011 | DeLonghi Microwave Ovens
I have a belling range gas cooker, i have just changed the thermo couple but now the gas is not coming through as much as it should, the relaese of gas is normally fast and you are able to hear it but now...
There is no reason why the gas level has dropped after the thermocouple was changed but the ONLY reason can be an accidental fault in the fitting or refitting.
So go over the same job and check from the gas line, the regulator and the burner. Use a good air jet to blow the passage clean. make sure there is good contact of the burner to the base for a good fuel mix.
check if there was any restriction inthe gas flow when the fitting was done. The fault can be only here, remove gas and use a air pressure to check the flow line, clean and set back.
Sep 18, 2010 | Microwave Ovens
The red light comes on that looks like a burner and then the machine shuts off.
Possible that the magnetron is heating beyond the limit. please do not swittch on without any source of conduction to cook or heat. Do the dry test with a cup of water and never run it dry.
If the cup heats then the micrwave is fine. if there is heating in the cabin remove and refit the magnetron.If not it can be deffective due to insulation failure.
Aug 29, 2010 | DeLonghi Microwave Ovens
I require ain instruction manual for a delonghi mw865f microwave
just open the link and enter the code given and download the manual
http://www.givemefile.net/manuals/_microwave_ovens/delonghi/file/27939.html
Apr 18, 2010 | DeLonghi Microwave Ovens
I have been given a DeLonghi 850 Microwave but have no instructions - is it possible to get some. It has a serial number of ED8525S-SBD. I tried to heat something but it wouldn't think I must be using the...
try looking for your manual here: http://www.delonghiusa.com/index.php?texts&pid=10
If you can not find it, try calling their customer service, and ask them to send you a manual!
help@delonghi-csservice.com
1 (800) 322-3848
Sep 09, 2009 | DeLonghi Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
