My HP compaq nc 6400 stopped working. When I press the power on button the amber light flashes three times and then nothing. Works fine without the battery. My battery is only 4 months old. I left the power supply plugged in most of the time. Was I wrong to do that?
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 13, 2010
I have a 2007 ES 350. Changed key fob battery,now nothing works. Only immobilizer security light is flashing and engine start stop button has amber colored light on
Be sure to use the correct battery, properly in place, clean the key contacts , See owner's manual for additional information.
There are specialized locksmiths for car keys
Oct 02, 2014 | 2007 Lexus ES 350
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
Compaq nc 6400 laptop no power on i check cahger ok power button ok **** still my laptop no on
More than likely the battery is defective, even with a charger it will not run if the battery is an open circuit due to failure.
Feb 07, 2012 | HP Compaq nc6400 (GJ982US) PC Notebook
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Aug 26, 2009 | Toshiba Satellite Pro 4600 Notebook
HP nx 7300
remove and, reinstall the memory...If that doesn't work disconnect each device i.e. DVD, wireless nic etc. repowering each time.
Aug 25, 2009 | HP Compaq nx7300 Notebook
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Computers & Internet Logo
364 people viewed this question
David Payne
David Payne
