Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
The gun part of the wond has a hold. will I need to replace the hold gun section? If so is their a replacement?
  • 487 Answers
Hi, if the gun section is just leaking, then you can replace the washers inside; otherwise, its a replacement, which is not cheap unfortunately; but most guns should fit your machine.
Posted on Oct 13, 2010
How do you load staples into a surebonder model 9630?
Loading a 995630. Hold gun upside down with front of gun in left hand. Open track release with right hand. Lay one section of 1/4" crown staples in the bottom of the gun itself, in front of the track. Slide track over staples. Store tool at room temperature. New gun needs 6 drops of air tool oil through the air inlet just before first use. If you do not have the recommended automatic oiler installed on your airline, you will need to manually oil with three drops every 3rd row of staples. Run PSI around 80 and never exceed 100 PSI on your air compressor.
Sep 01, 2014 | Surebonder Pneumatic Stapler
Karcher gun leaking
the gun needs replacing, non servicable, interchangable with many brands
Mar 21, 2014 | Garden
I have a framing nail gun and air is leaking around the trigger. How do I get the trigger off to replace it or replace the rings?
in the tip section I have detailed instructions on how to remove the trigger valve assembly. You might be able to click on my icon to get to the page, let me know if you need more assistance.
Sep 06, 2011 | Stanley Bostitch Nail Gun
Dropping the cross membet the bolts a rusty and wond break loose
If you spray the bolts & use 1/2" drive sockets & long
ratchet,at least 15" to 18" they will come loose
You may be able to get a 1/2" impact air gun in there,
to vibrate & start things off. Not my favorite tool,but some
times necessary,only on large bolts --1/2",12mm or larger
Jul 30, 2011 | Chevrolet 1500 Cars & Trucks
How do you fix/repair 15 guage nail gun o-ring for the nail gun triger. air is leaking from the triger
the trigger assembly would need replaced. I have detailed instructions in the tip section on the removal and installation of the trigger valve. Let me know if you still need more assistance.
Jul 07, 2011 | Stanley Bostitch Nail Gun
I have the 2 gallon sprayer the tip of the spray wond snapped off I need to find replacement ends for my wond
generic parts can be purchased from Home Depot or Lowes. I do it all the time. Might have to modify and "make them fit" but usuallt it isn't too tough. Or, just keep an eye out this time of year for people throwing defective sprayers away. Might be able to use parst from their sprayer to fix yours.
Apr 26, 2010 | Roundup Garden
Beeman RS2 model 1074 pellet gun
i found a guy online and he was able to help me.not sure if i can tell how or who helped me so i better not. thanks anyway
michael
Mar 30, 2009 | Sport & Outdoor - Others
Need new gun and connection to gun
The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
Dec 14, 2008 | Coleman Powermate DuraBuilt 1400 PSI...
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
163 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
