How many people are here, in my house. - Computers & Internet
    Brigadier General:
  • 10,406 Answers
In my house, there are three: ME, MYSELF, and I.
Is your house the same size as my house?
Posted on Oct 13, 2010
Where can I sell my house as fast as possible?
You can sell your house fast by referring to an online agent as there are many online organizations that work for this purpose. They would help you get the best price of your house more efficiently. Just perform a research to find a trustworthy website and you are done. I have also sold my house this way only and got the right amount for my house.
Jun 16, 2017 | Cars & Trucks
4th lord in 12th house means will live away from home land?
4th house belong to education and 12th house is travel house which belong to foreign land so native may go for foreign for study purpose. It may also cause for foreign residence because 4th house also belong to residence. It may be known by involvement of planet and its significant and other relationships with 4th house and its Lord in 12th house.
4th house is belong to happiness and 12th house belong sleeping so 4th Lord in 12th house indicating native may enjoying happiness of sleeping.
Jan 04, 2017 | Horoscopes
How do I replace a veneto flush piston in my toilet?
The piston sits inside the upper valve housing. The upper valve housing comes off by twisting the upper housing counter-clockwise. When you lift the valve housing out of the tank you will see the flush piston extruding from the bottom of the housing. The flush piston can be pulled out of the housing.. Yes, it just pulls out. And you just push the new piston in place.. Secure the valve assembly back into the tank by rotating the housing clock-wise.. Some Veneto toilets have two clips on the housing which secure the housing in place.
Jul 11, 2014 | Porcher Home
Replace thermostat
Two big hoses attach to your radiator. Look for the one that goes back to the TOP of the engine. There is a housing with two bolts in it that the hose connects to. Drain radiator, remove hose. Remove the two bolts. Remove the housing. Thermostat is inside housing or still on engine. It just pulls out. Remove any remaining thermostat housing gasket material from the housing and the engine. Install new thermostat. Should only fit in one way. Install new thermostat housing gasket and the housing. Reattach hose and fill radiator, leaving the cap off. Turn on the car and wait until car gets to warm condition. You will see the water start to move from the radiator to the engine when the new thermostat releases at the proper temperature. Replace the radiator cap and clean up, you are finished.
Oct 09, 2010 | 1993 Cadillac DeVille
How do i remove rhe thermostat from the housing in a 2004 GMC Envoy
Hello, to remove the thermostat from the housing , follow this steps:
  1. Remove the necessary coolant from the radiator.
  2. Remove the alternator, Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
  3. Remove the thermostat housing bolts.
  4. Remove the thermostat housing from the engine block.
  5. Clean all of the surfaces of the thermostat housing.
  6. Clean the sealing surface of the engine block.
Thanks
Aug 17, 2010 | GMC Envoy Cars & Trucks
Where is the thermostat located
Fig. The location of the thermostat and its housing on the 3.7L engine
  1. Disconnect negative battery cable at battery.
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Remove splash shield.
  5. Remove lower radiator hose clamp and lower radiator hose at thermostat housing.
  6. Remove thermostat housing mounting bolts, thermostat housing and thermostat .
To install:
  1. Clean mating areas of timing chain cover and thermostat housing.
  2. Install thermostat (spring side down) into recessed machined groove on housing assembly. Make sure rubber seal locating tab is positioned in the corresponding notch in the housing.
  3. Position thermostat housing on timing chain cover.
  4. Install two housing-to-timing chain cover bolts. Tighten bolts to 105 inch lbs. (12 Nm) torque.
  5. Install lower radiator hose on thermostat housing.
  6. Install splash shield.
  7. Lower vehicle.
  8. Fill cooling system.
  9. Connect negative battery cable to battery.
  10. Start and warm the engine. Check for leaks.
Hope helps (remember rated and comment this).
Aug 06, 2010 | 2002 Jeep Liberty
Please choose the correct steps for the size of engine that you have:
4.5L & 4.9L Engines
  1. Drain the coolant to a level below the thermostat housing.
  2. It may be necessary to remove the upper air filter assembly on some models.
  3. Remove the 2 bolts securing the upper thermostat housing to the lower housing.
  4. Remove the upper thermostat housing.
  5. Remove the thermostat and O-ring from the lower housing.
Thermostat installation—4.5L and 4.9L engines
To install:
  1. Install the thermostat and a new O-ring to the lower housing.
  2. Install the upper thermostat housing to the lower housing. Tighten the thermostat housing bolts to 20 ft. lbs. (27 Nm).
  3. Refill the cooling system using a 50/50 mixture of water and ethylene glycol antifreeze.
  4. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
4.6L Engines
  2. On some vehicles, access is easier if the front-end beauty panel and the air cleaner are removed.
  3. Remove the 2 bolts securing the thermostat housing to the intake manifold.
  4. Remove the thermostat housing.
  5. Remove the thermostat and O-ring from the housing.
Thermostat installation—4.6L Engine
Loosen the upper radiator hose clamp at the thermostat housing
Remove the upper radiator hose clamp from the thermostat housing
Remove the thermostat housing retaining bolts and . . .
. . . remove the thermostat housing from the engine
Separate the thermostat from the housing
To install:
  1. Install the thermostat and new O-ring to the housing.
  2. Install the thermostat housing to the intake manifold. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  4. Install the air cleaner and beauty panel, if removed.
  5. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
May 23, 2010 | 1996 Cadillac DeVille
Where is the thermastat 2006 la cross
3.6L Engine
  1. Remove the heater hoses.
  2. Remove the throttle body.
  3. Remove the radiator water pipe outlet.
  4. Remove the thermostat and housing.
    NOTE The thermostat and housing are replaced as a complete unit.
  5. To install, reverse the removal procedure. Tighten the housing bolts to 15 ft. lbs. (20 Nm).
3.8L Engine
  1. Remove the fuel injector sight shield.
  2. Partially drain the cooling system.
  3. Remove the radiator inlet hose from the water outlet housing.
  4. Reposition the wiring harness from the water outlet housing stud.
  5. Remove the water outlet housing bolt and the stud.
  6. Remove the water outlet housing and the gasket.
  7. Remove the thermostat.
  8. Clean and Inspect the water outlet housing gasket mating surfaces.
To install:
  1. Install the thermostat.
  2. Install the gasket and the water outlet housing.
  3. Install the water outlet housing bolt and the stud to the water outlet housing and tighten to 20 ft. lbs. (27 Nm).
  4. Install the wiring harness to the water outlet housing stud.
  5. Install the radiator inlet hose to the water outlet housing.
  6. Fill the cooling system.
  7. Install the fuel injector sight shield.
Oct 13, 2009 | 2006 Buick LaCrosse
NEED LOCATION OF THERMOSTAT IN 1991 CADILLAC SEVILLE
0900c15280090476.jpgThermostat installation—4.6L Engine 0900c15280090477.jpgLoosen the upper radiator hose clamp at the thermostat housing 0900c15280090478.jpgRemove the upper radiator hose clamp from the thermostat housing 0900c15280090479.jpgRemove the thermostat housing retaining bolts and . . . 0900c1528009047a.jpg. . . remove the thermostat housing from the engine 0900c1528009047b.jpgSeparate the thermostat from the housing To install:
Nov 27, 2008 | 1992 Cadillac DeVille
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
