Question about RCA Televison & Video
Rca remote control
My remote lost it's ability to function. I had it programmed and it lost the code I had it wrote down and tried to enter it again but no luck.I have done all the code searches in the booklet that come with it and still it won't work.
I can't afford your price so I'll look somewhere else.
Posted on Jun 02, 2008
I have an RCA remote and have lost the book. I can't remember how to program it and what the codes are for a Sanyo T.V. Thanks Diane
Hello
The setup codes for RCA RCR 312W remote control with Sanyo TV are:
10054, 10154, 10159, 11142
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control.
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control.
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6. To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality
Ok.
Jun 29, 2011 | RCA RCR312W Remote Control
Tip
RCA Universal Remote Code Entry Models RCR312W - RCR311BN - RCR311BIN RCR311SN -...
RCR311SN - RCR311STN
Would you like help entering the code to program your RCA Universal Remote? You can look up the codes for your remote on this list.
Here are the steps to enter the programming code into your RCA Universal Remote:
  1. Manually turn on the device you want to control.
  2. Find the Code List. Locate the section for the type of device you would like to control and find your brand in that section. Write down the code(s).
  3. Press and hold the device key you want to program. The on/off key light comes on.
  4. While holding the device key, use your other hand to enter the first five digit code for your brand from the list. The on/off key light goes off after the first digit.
  5. When finished entering the code, keep holding down the device key and look at the on/off key light. If the light is on, you have successfully programmed your remote. If the light blinks four times and turned off, you have entered a code number that is not in the code lists or have missed a step in the code procedure. Try the previous step again.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
TRYING TO PROGRAM REMOTE IT IS A RCA REMOTE LOST INSTRUCTIONS TO REMOTE.
HI, Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search: 1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 08, 2010 | RCA Universal Remote Control
I HAVE A RCA 3 DEVICE REMOTE CONTROL AND LOST THE MANUAL.I NEED THE CODES TO PROGRAM IT. WHAT DO I NEED TO DO?
Thank you
Nov 06, 2010 | RCA Universal Remote 3 Device Remote...
Tip
I hope that helps.
on Apr 07, 2010 | RCA RCR311B Remote Control
I LOST MY PROGRAMING INSTRUCTIONS AND CODES FOR MY TV THE MODEL OF MY UNIVERSAL CONTROL IS RCR4358 ITS A RCA
The code list is located at the following website: http://www.revoxremotes.com/Remotes/RCA_R55L8_Codes.pdf
Find your TV and hold the TV button on the top left. While holding the TV button, enter in a 4 digit code (they should be in the 1000's) - then release the TV button and try the channels or volume up or down
EXAMPLE: TV(1047) release TV button
- try all 4 digit codes associated with your TV
- once the code is entered, try it by clicking channel up or down
- hope this helps, this can be frustrating
- If the remote responds, stop trying codes, your remote is programmed
- WRITE DOWN THE NUMBER FOR YOUR TV WITH A SHARPIE ON THE REMOTE ITSELF THIS WILL PREVENT FURTHER WASTING OF TIME
Feb 06, 2010 | RCA 4-in-1 Universal Remote Control
How to program a RCA remote control I have the
press TV and SET light on... enter code press SET....all done
Sep 10, 2009 | RCA Universal Remote Control
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
RCA x-100 remote lost is this one all compatible?
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 04, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
