Canoot get surround sound from back speakers - Audio Players & Recorders
  • Anonymous Sep 25, 2008
    surround works, but very low, also my display does not show my center or surround speakers.
  • 151 Answers
MAKE SURE YOU HAVE THE SPEAKERS WIRED INTO THE SURROUND NOT THE SURROUND BACK. IFF YOU HAVE SPEAKERS WIRED TO SURROUND MAKE SURE THE VOLUME FOR YOUR REARS IS TURNED UP.ALSO CHECK THAT YOU HAVE AMP SET FOR SURROUND SOUND,IE DOLBY DIGITAL OR PRO LOGIC TWO.
HOPE THIS HELPS.
Posted on Jun 02, 2008
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
Surround sound will not work sr805
Did the speaker cailibration work on the speakers in question?
If YES, then the program material or settings you're using don't require the rear speakers.
By "Back" do we mean Surround or Surround Back? Surround Back speakers are the 6th and 7th channels in the 7.1 matrix. Not all source material has programming for them. But when using any 7.1 digital surround mode you can get anything, even stereo recordings, to output something from every speaker.
If NO, check your connections...
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=TXSR805_QSS_En_0330.pdf
Dec 21, 2008 | Onkyo TX-SR803 Receiver
No sound from back speakers
Remember the rear speakers are called surround... Did you select surround on the unit? if it says stereo then you will only get fronts, select surround to get the rest.
Jul 13, 2008 | Sony STR-DG510 Receiver
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
688 people viewed this question
 Grubhead
Grubhead
