It is about our Panasonic washing machine model no. NA-F70A6. The problem is the continuous water intake and water drain at the same time and it doesn't function properly.
  • Athi Letc Aug 13, 2013
    u need check the host for task thing inside if want call me this numbers 0162426864
  • 249 Answers
SOURCE: washing machine
something caught in pump or bottom drum hose,check filter also!!
Posted on Mar 21, 2008
SOURCE: The water inlet does not stop during the entire
Its simple..just follow step by step as below:-
  1. Switch off and unconnected both power & water supply.
  2. Lay the unit with the back side facing up.
  3. remove the back & bottom panel
  4. you will see the valve on the bottom tub.
  5. Unscrew the valve cap.
  6. Dismantle the valve by release the connector between steel bracket & hook (white plastic 'T' shape) using small 'playar'
  7. Then you will see a 20 cents coin ( keep into your tabung gajah)
  8. Use the old toothbrush to clean the black rubber valve.
  9. Assemble everything.
  10. Thats all.
Posted on Jun 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
richroth
  • 9472 Answers
SOURCE: The error code U12 shows
The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
Posted on Jul 31, 2011
SOURCE: washing machine not draining water during washes
I have had the same problem. Someone told me to clean the pump filter. I have a front loader and the pump filter is in a little door down the front of the washing machine. You turn the thing in there counter clockwise (water may cascade out - keep bucket handy) then clean flint/soap out of the filter.
This didn't work for my washing machine however, so if anyone has any ideas (ie. how do you actually check if the hose from the washer to the sink is blocked - mine doesn't detach) would be most appreciated
Posted on Dec 09, 2011
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
Please tell me if an NA VR5500L Panasonic washing machine has a water heater? If it does, how does it work? the drain coming out is cold. THANKS A LOT
The only appliance that heats water internally for cleaning is a dishwasher. Washing machines don;t heat water. It's not efficient. Various industries have work their hardest to keep you from using hot water or the chemicals(phosphates) that help you clean better without it. Dishwashers warm 3 gallons no more than 20 degrees during a 30 minute cycle. Some washing machines are designed to avoid hot water completely and call themselves energy effient to get people to buy them. My wife would cut my heart out if I brought one home.
Aug 24, 2015 | Washing Machines
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
Why is the Panasonic NA-F70B3 on its very first test wash started rattling really loud and banging on the side of the machine Casing
Any loud rattling sound is bad news. The drum should not be banging on anything!! Return or file a complaint with where you purchased it immediately. Do not wait, there will be a time-limit on returns and after that you are on your own.
Jun 14, 2014 | Washing Machines
Panasonic Top Load Washing Machine (NA-F70A6) won't drain
Try to yank the clogging by a small gripper claw tool that you can purchase from ACE hardware. It is like a long tool with a push end that when you push, a set of 3 small claws go out. This would go in between the tub and the drum.
Jan 14, 2014 | Washing Machines
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
Error code h41 on panasonic washing machine model na-168vx2
U11
The washing machine cannot drain
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Feb 15, 2011 | Washing Machines
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Got error code u11
u11 is not a valid error code - please recheck.
Mar 12, 2009 | Washing Machines
Washing Machines Logo
365 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
