Question about Dryers
Dryer not spinning and making grinding noise. already replaced belt and pulley
  • 176 Answers
Check the fuse or door switch or motor
Posted on Oct 13, 2010
Tip
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Your dryer has started making noises. The common noises that can happen are squeaks, grinding, bumping, clicking, or knocking. I will give some of the common reasons why your clothes dryer could be making these noises.
Loud noise from your dryer often is the result of excessive wear of the parts inside of the clothing dryer.
Many dryers use a type of glides or slide for the drum of the dryer to ride on. As the dryer heats then up they wear away. The heat from the inside of the dryer and the friction heat will eventually wear them down. When the glide material is worn away the metal of the drum will start to rub against the metal support behind the glide. Metal on metal will make a very irritating squeaking noise, or grinding noise. If this happens, replace the glides.
Other dryers use a type of wheel or roller to support the rotating drum. These rollers turn on a sort of bearing that in often no more then a pin through a bushing. After a period of time the lubrication will dry up or otherwise go away and the assembly will quickly wear out and start to make a clicking noise, or a knocking noise, or even a grinding noise. In any case these often make a loud noise that can be very annoying. If you have a wheel or roller that is making noises then replace all of them, because the others are soon going to go bad also.
On some dryers there is a rear drum bearing. This center spindle supports the drum instead of rollers, wheels, or glides. This spindle will have a bearing assembly of some type that it spins on. This bearing also may start to squeak, grind, or make a loud noise.
If you have this type of dryer then you can replace this when it goes bad.
Another source of dryer noise is the belt. The belt often will make a different noise that will be more of a knocking or thumping noise. Pieces of the belt may come out of the belt and it still is not broken. As the gaps in the belt run over the idler pulley or the drive pulley the belt will make a thumping or knocking noise.
The idler pulley can also be a source of noise. This also has a bearing in it that will wear out. The noises made from this are similar to the rollers or wheels. If you have these kinds of noises coming from your dryer, you need to figure out what the exact cause of the problem is so that you know you are changing the right parts. Or you can just change all of the rotating parts to make sure that you get the problem fixed. The parts involved are not that expensive to replace.
Finally the blower wheel that moves air through your dryer can become clogged with dirt and lint or just plain wear out. If it is loose or out of balance it will make all kinds of funny noises. Cleaning it may help but replacement is probably the best fix. If it is still noisy after cleaning, then replace it.
This should give you a good overview of the possible causes for noise from your clothes dryer. As you can see there are numerous possibilities or causes for noise. Take your time and eliminate them one by one till the cause is found. Repairing them is not that hard and the parts are not that costly.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Mar 26, 2010 | Dryers
2003 buick regal fan belt wobbling grinding noise over heating
Possible water pump. Remove the belt and grab the pulley , wiggle and spin. Check the other pulleys as well.
Dec 22, 2013 | 2000 Buick Regal
My 2000 Ford focus was making a grinding noise when driving the power stering went out and I look under the hood and the belt was loose what do I do... O battery light is now on.
sounds like your belt broke. replace with a new belt. battery light is on because the belt is not spinning the alternator. If it busted you should be able to pull it right out. Make sure to check the tensioner pulley, alternator pulley, power steering pump pulley and ac compressor pulley for free play(if you can make it spin with your hand it's good) and make sure that they're not binding or making any grinding noises. If the belt has never been replaced, then most likely it gave out.
Sep 24, 2011 | 2000 Ford Focus
Speed Queen dryer makes intermittant squeaky noise and when it stops, makes screeching noise. I replaced the belt and a front drum seal already. Not much omprovement. How can you tell if Pulley and the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Amana Dryers
The belts continue to make a loud screeching noises when i drive over 55. Sometimes when the car is idling the belts make noise. Could it be the tension pulley.
it could be the tensioner, water pump, alternator, A/C compressor, power steering, or even a really bad serpentine belt. The only way to be sure is to remove the s-belt and spin-check the pulleys and listen for squeaks or grinding bearings.
Jan 13, 2011 | 1984 Buick LeSabre
Intermittent grinding noise as the drum spins. sounds as if the drum is out of balance
replace the belt and the idler pulley for the belt. It has a worn bearing causing this awlful noise
Jan 13, 2011 | Maytag PYE2300AY Electric Dryer
Dryer makes loud grinding noise when you cut it on
The dryers drum runs off a belt as you may know to spin it around to dry clothes. This belt is attached to a belt tensioner also to keep the belt snug. This tensioner has a roller with a bearing in the middle of it. Most bearings are made of brass and wear out causing it to grind
I would replace the belt & tensioner pulley as a unit. Sears will have these two parts selling together as a kit. Go online to view with your make and model number to see
May 31, 2010 | Whirlpool LER4634J Electric Dryer
Noisy Dryer
You'll have to take the back off and fisically look and see if a pulley is bad. Hoped this helped, if not let us know thankyou for asking.
Mar 14, 2009 | GE Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
