Question about Health & Beauty
Manual for a corning scholar 425 ph meter - Health & Beauty
I want to know how to store more than 20 values added with its squre in memory and perform other functions on fsx 991es plus
Sorry you cannot.store many numbers. Memory locations are at A, B, C, D, E, F in addition to X and Y. But why would you want to store the squares since the calculator can calculate them readily.
To perform other functions (more than 400) do read the manual.
Dec 08, 2016 | Office Equipment & Supplies
A scholar is what
Someone who learns is a scholar, though the word also means someone with a lot of knowledge in one subject. If you know a lot about books, you could be called a literary scholar.
It doesn't take a Latin scholar to understand the word scholar. It probably reminds you of school, scholastic, and scholarship. That's because they all share the Latin root schola which means school. A scholar in the academic sense usually has his or her area of specialty in the humanities as opposed to the sciences.
Apr 24, 2015 | Computers & Internet
Haw do i calibrate metller toledo mp220 ph metter
1ST YOUR GONNA NEED BUFFERS:
All pH meters require calibration standards to ensure that the readings are traceable to a standard. Always choose a pH 7 buffer plus at least one other pH value close to your expected measurement range. Using solutions of known pH value allow you to adjust the system to read accurate measurements. Calibration should be performed before each reading or each set of readings.
After that this model has auto buffer select and it will tell You what buffer you put it in , also will ask if you want to correct it as well
Dec 05, 2014 | Measuring Tools & Sensors
My pH meter flashes "16"
John: need more info , whats make and model of meter , How old is electrode ? was it kept wet all the time? the 16 is it in a place where a ph value should be displayed or just on the display someplace ? it might be a diagnostic code ?
Oct 21, 2014 | Measuring Tools & Sensors
What are pH meters used for?
pH meters are used to measure the acidity or alkalinity of a liquid, usually water.
Jan 05, 2014 | Measuring Tools & Sensors
Do we need to calibrate the pH meter every time we measure an acidic solution or alkaline solution?
No I have a hanna phep for my koy pond I never calibrate it just clean it in fresh water every use shake it in water
Feb 28, 2011 | Hanna pHep pH Meter with Solutions
How much oil or corn do you use in the Back to Basics Pop Corn Popper for the stove
unless you have the instruction manual, only trial-and-error will tell you. Start with 2 tablespoons of oil and 1/2 cup of corn kernals. If there is oil left after the corn is popped, decrease the amount of oil by a teaspoon. If the popped corn is burned, increase the oil by a teaspoon. As for the corn, if the pot is full when the popping is done, 1/2 cup is the right amount. If the popped corn over flows, 1/2 cup is too much. Vary the oil and corn until you get it right. Good luck! I love popcorn, so I wish you the best.
Feb 02, 2010 | Back to Basics 6112304 Popcorn Maker
Dario Grade O Meter Instruction manual needed
Hi Tracy,
I have the book, the address in the book is Dario Grad-O-Meter 12660 Lull St. North Hollywood, CA 91605 ph (818) 765-3635
Oct 25, 2008 | Measuring Tools & Sensors
Health & Beauty Logo
498 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
