Question about Sony Computers & Internet
How do you stop hibernate and stand by? - Sony Computers & Internet
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Power
Click to disable stand by
Click the Hibernate tab
Disable hibernation
Posted on Oct 13, 2010
Hi, i'm using windows xp on my latop, i used to have a hibernate option when i click the 'turn off computer', after reinstalling my windows, i can now only see shut down and restart. how do...
Hello and Welcome to FixYa!
Click Start >> Control Panel >> Power Options >> A dialog box will open, there will be a Hibernate Tab at the top of it >> Check the option there "Enable Hibernation".
When Done, click Start and Turn off computer, The three buttons you see one will be Stand By. Press and hold the Shift key. Stand By will become hibernate. Click it. You are done.
If you have any issues following it, do tell me.
Concerned, Nooh: Team FixYa!
Jul 11, 2011 | Computers & Internet
Should I Leave my PC in sleep mode after use?
Go green & use hibernate instead.
Well, actually a lot also depends upon what is the duration of you not using the system between breaks. Hibernate anyways is quicker than a normal boot process. I would highly recommend hibernate.
Sleep - is a combination of stand by and hibernate. Be default most of the newer system will write the memory info into hibernation file & put your system to stand by mode. After certain period say 2-3 hours your system will go into hibernate mode. (these are standard settings & unless you keep coming back in 15-20 mins you should use hibernate & contribute towards environment too)
Oct 07, 2010 | Computers & Internet
My hibernation option is gone.....
Hibernation may be disabled by default in XP.
Go into Start > Settings > Control Panel > Power Options. Click on the Hibernate tab, then check the Enable Hibernation check box to enable it.
Otherwise:
You can start hibernation of your PC manually, if hibernation is enabled, by:
1. Selecting 'Turn Off The Computer'' from the Start menu.
2. Normally the left choice on the resulting pop-up window is ''Stand-By''. But, if you hold down the Shift key it becomes ''Hibernate''. So holding down the Shift-Key and clicking on the resulting ''Hibernate'' button (the left-most button) will cause your computer to start hibernation mode.
Note that many computers also have a button for starting hibernation mode also. Often pressing the Power button while the computer is on will cause it to go into Hibernation. (Sometimes desktop computers have this option disabled, but it can be enabled through some Setup menu item (unless a special key has been assigned to do it on the keyboard.)
Hope helpful.
Mar 18, 2010 | Compaq Computers & Internet
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
How I can enable Hibernate and Stand By button? I have windows XP SP3
Here is a tip to know how to use and enable Hibernate and Stand By button.
In the keyboard to find the button for Hibernate and Stand By button.
Sep 14, 2009 | Computers & Internet
I have the same problem with Stand by on my IBM Thinkpad
Try going to performance and maintenance then power options.Make sure the power scheme is set to Portable/Laptop.Make sure all the drop down boxes are set to NEVER.Go to the hibernate tab and uncheck Hibernate.Be sure to push apply.Then reboot.That may stop your problem.
Aug 07, 2009 | Toshiba Satellite M100 Notebook
Cooling fan runs constantly coming off stand-by
Has it always done this or is this a recent problem?
Try this: right click on your desk top's start screen, select properties, select screen saver, select poweer, select hibernate. Make sure that hibernate is checked and select apply. Now when you hibernate your computer will remember all the info you were working on AND it should make the fan run normally on start up.
Not all computers have the hibernate feature and it cannot be added, so let's hope yours was built with it at the factory. Good luck!
May 01, 2009 | Computers & Internet
Hibernation
your problem your oparating sytem.Reinstall it then solve this problem.
Feb 21, 2009 | Mercury P4VM800M7 Motherboard
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Software problem
Does this happen every time you download something from the internet?
Has the computer turned itself off while doing anything else?
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
740549c.jpgBased on own preference, it’s possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  1. Click OK button.
How to Disable Notebook Computer to Stand By or Hibernate on Closing Lid in Windows XP
  1. Log on to your computer as an administrator. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
e461aeb.gifAgain, any other settings such as Stand by and Hibernate can be set based on own preference.
  1. Click OK button.
Let me know if this helps - if not - PLEASE, further clairify so we can continue to find a fix for your problem....
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
