Question about Roper 24 in. RUD1000DB Built-in Dishwasher
MY Roper WU0800x1 dishwasher does not spin the washing arm. In fact, water just bubbles from the center. I don't know if I need a new water pump or if there are parts missing; the unit was in my RV when I purchased it used. Does anyone have a schematic of the internal parts?
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
Posted on Oct 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Posted on Mar 12, 2009
  • 132 Answers
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
Posted on Mar 26, 2009
localwonder
  • 6784 Answers
SOURCE: water into washer
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jun 11, 2009
Wash arms don't spin
see this cause and fix it
1) see for binding wash arms and repair.
2) propeler +coupling in pumps defective or stuck mechanic repair.
3) motor defective, test it. and repair.
see the diagram
Jul 10, 2012 | Thermador 24 in. DWHD64CS Stainless Steel...
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
What if your maytag dishwasher is filling with water but neither wash arm is moving? Is this a simple fix with a new part and if so what part or is it more serious.
The wash arms are moved by the pump pumping water through the arms if they move if you spin them with your hand then the pump is not running. It could be that the motor is not getting power from the circuit board or the pump motor is locked up or burned out. So it would take a new motor.
I don't know how old this is but the newer ones were direct drive it could be possible that this one could be belt driven so it may only need a belt..... Hope this helps.
Jan 02, 2011 | Dishwashers
No water pressure.. bad pump or motor?
Try filling water from the front manually. Check whether every thing works normal.
If works OK, check your water inlet for free flow.Try the inlet hose externally by flushing water through the hose.
Check whether any air lock. If air lock noticed, air will flow in broken streams.Flowt will become OK after some time.
Try now in the machine by connecting.
Mar 31, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dirty dishes
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher.
The motor (and pump) located beneath the dishwasher.
Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem.
First of all: filter plate clean? Clean any locked hole.
1) Can you remove the upper spray-arm and verify if holes inside are locked by any residus. Clean the holes , and check if pure water come out when you fill the center hole with some water.
2) Switch on the dishwasher , coldest wash cycle dish-washer empty and without the upper spraying arm. Once you hear water streaming in, open the door and look if a little water fountain comes out from the center hole where the upper spraying arm was fixed. If not, this canalisation is blocked and should be cleaned. Try to continue the wash cycle, often the water pressure will clean itself this canal. Check also lower spray arm: it should be rotating a while and ejecting water thru its holes. If not, verify this canalisation as well.
3) Put the spraying arm again on its place, verify also the sealing else water pressure is going down and spraying will not turn and spray water.
4) Again, continu a wash cycle, open the door and look; upper arm should be rotating and some rays trown out.
Hopefully, this helps .
If not, pump pressure may be low; have a repair verify, can be that only brushes in the motor must be replaced, can be the pump worn out and to be replaced at all.
Aug 12, 2008 | Asko D1776 Built-in Dishwasher
Water not pumping through wash arms
It would be helpful to know the model no. of your dishwasher.
I few things to check
1. is the water getting into the unit - tap on etc.
2. are the spray arms free of debris - remove and clean the holes
3. do you hear the arms rotate when unit is turned on.
4. how do you know the water is not pumping through the arms
Hopefully we can diagnose the problem for you.
Jan 24, 2010 | Jenn-Air Dishwashers
Washer arms do not spin only squirt water
Sounds to me that the arms are pluged. The arms can be removed by removing the center nut or screw. Remove them and run it with them out and listen if you hear a strong spray, you should. Wash the arms out in a sink paying attention to the water coming out the small holes that nothing is trying to come out of them and that the water flows free, then reinstall them. let me know how it goes.
Nov 16, 2009 | Dishwashers
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Apr 27, 2009 | Moyer Diebel 24 in. 501HT Built-in...
Roper 24 in. RUD1000DB Built-in Dishwasher Logo
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
