Battery isn't charging with the proper setup - Computers & Internet
  • Larry Miller May 11, 2010
    this is a desktop forum, are you talking about a laptop?
    Problem Solver:
  • 33 Answers
Is this laptop as larry already asked or do you mean the CMOS battery
Posted on Jun 01, 2008
Charging problem Motorcycle
you need 12.6 to turn on the regulator to allow it to charge at 14.25..and than should read 13.75 on shut down..till the battery cools back to 12.6....no 12.6 no charge...new battery needed
May 05, 2013 | 2000 Honda VTR 1000 SP-1 (RC51)
Battery going dead when truck is not running
If the battery isn't over 4 years old, then you
have to pull one fuse at a time or put an amp
meter in series with either battery cable to see
where the drain is.
Some Module may not be timing out or there is
a problem with the alternator
Every vehicle is wired different ,simply can't give you
a specific cause,has to be tested in the proper way
to stop the problem
Nov 16, 2012 | Ford Cars & Trucks
Battery dead after long ride
Sounds like a charging problem. Charge the battery, then start the bike. Run the rpm's up to 2000 while checking voltage at the battery with a volt meter (dc volts). Voltage should be 13.8-14.2dc volts. If you don't get close to these readings, the charging system isn't working properly.
May 07, 2012 | 2000 Harley Davidson FLSTF Fat boy
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
Battery does not stay charged.will start after being charged but when i go somewhere will get me there and will need jump to get home
It could be one of 3 things.
1) Your alternator belt is loose and so your battery isn't charging properly
2) Your battery is dead, needs replacing.
3) Your alternator is faulty and needs repair/replacing.
As its most likely to be 1 or 2, especially if you battery is more than 2 years old. I'd go to a garage/battery shop and ask them to check it. More than likely with a view to replacement.
Sep 12, 2011 | 1999 Lincoln Navigator
Engine is a re-build done less than 100 miles, was starting ok but now it wont turn just continuous clicking like starter wont engage!
Sounds like the battery isn't charged enough to power the starter.
Take the battery off and charge it properly with a proper battery charger.
Refit and it should be fine.
If not, it's new battery time.
Aug 05, 2011 | Harley Davidson XL 1200 C Sportster Custom...
My car keeps dying out, could it be the battery or alternator?
unlikely, if it starts the battery is good because it just started the car and the alternator is good because it charged the battery the prior time it was running. i would put some thought into a fuel supply problem, such as the pressure falling off rapidly after a start; or something getting hot in the ignition systrem and failing causing a loss of spark.
Jul 25, 2011 | 1993 Ford Probe
Isn't starting. battery isn't getting a charge. bike starts once the battery is charged
Your battery MOST LIKELY has lost some of the battery cells, which will cause it to get a partial charge which will show it as a FULL charge when in fact it isn't getting a full charge. You should try taking it to get the battery tested and they can tell you if it needs to be replaced. I would guess they are going to replace it for you. A new battery should run around $90 for a motorcycle. Let me know if this helps you out. Jeff from fixya
Jun 11, 2011 | 2007 Hyosung GT650R TTC
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
Charger plugged in but battery isn't charging. laptop only comes on when plugged.
If you've been using that same laptop battery for a few years then it probably needs to be replaced. Batteries get old and stop working properly after a while. You'll have to go out and buy a new one.
May 10, 2011 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
