Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
How do you confirm clean air is comeing out off the compressor
    President:
  • Dewalt Master
  • 1,383 Answers
The best way to determine if air is reletavely clean is to make sure that the air filter is clean and that you drain out water from tanks daily. For a visual/ verify that air is clean, install a water trap /filter to the end of the airline like the one pictured here:
http://www.harborfreight.com/air-line-filter-43242.html
Good luck
Posted on Oct 13, 2010
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
Compressor comes on but wont blow cold air
Hello jpaul, I understand that your air conditioner is not cooling properly. Here are some simple troubleshooting tips to help resolve this issue:
· When was the last time the filter was cleaned? Restricted air flow from a soiled air filter can cause air conditioner to not cool properly. Make sure there is nothing blocking the airflow to the unit like blinds, drapes, furniture, etc which could restrict air distribution.
· Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc since the coils could possibly be blocked or dirty.
· Verify that the plug is not damaged and try resetting the unit. This can be done by pressing the GFI plug on the unit.
· Do not use an extension cord.
If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Jul 31, 2013 | Frigidaire Heating & Cooling
When I push reset button all lights come on for about 2 seconds and trips reset breaker in plug.
Hi chip faust - When was the last time the filter was clean? Restricted air flow from dirty air filter can caused air conditioner to turn on and off rapidly. Make sure there is nothing blocking the airflow to the unit like drapes, blinds, furniture, etc which could restrict air distribution. When was the last time you cleaned the outside condenser coils? Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc. Verify that the plug is not damaged and try resetting the unit. If any of these suggestions prove to be ineffective, then the unit could possibly have faulty PC power board, faulty compressor or power supply. Connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 23, 2013 | Frigidaire FAH106N1 Wall/Window Air...
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Sep 09, 2012 | Coleman Powermate 27 Gallon Air Compressor
What causing hot air to come out of air compressor cylinder
The air is always warmer coming out of a compressor. As air is compressed it builds heat, also the mechanics (friction) of the compressor builds heat. So you add these two together and you get some rather warm air out of a compressor, especially if it runs for a while. I hope this helps.
Apr 23, 2012 | Air Tools & Compressors
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
Air conditioning controls
Sounds like a bad switch.
Dec 15, 2008 | 2004 Mazda 6
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
237 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
