Question about Whirlpool EL7ATRR Refrigerator
The top three shelves of the freezer thawed all of my meats. The bottom two shelves and drawers stayed frozen. I removed all foods, tossed what was ruined. I unplugged the unit, cleaned it out and plugged it back in. When checked it this morning it was cold but not at freezing temperature.
    President:
  • 1,216 Answers
Ok The problem is that the fan is not running. Do the following first remove the shelves from the freezer and take the screws that holds the panel; there you will find the fan, put some w-40 on the fan and help it spin until it spins on its own. if the fan does not start you must replace the fan. 90% of circulation and cooling problems are caused by this fan.
Posted on Oct 13, 2010
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
Meat on top two shelves unthawed while bottom two shelves is frozen and has stayed frozen for three days. Air does not appear that cold coming out of top of freezer.
hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater. now if there is frost only on the bottom or top of evap coils u may have sealed sys problem if u got an ? feel free to write me..
Apr 19, 2011 | Kenmore Freezers
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Quit staying cold
TV is no problem and will have no effect...
This tip will help you see what has happened with your unit..
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Apr 22, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Freezer . Food is chilled not frozen. Checked troubleshooter suggestions in book. eg A small bottle water left in freezer overnight is only cold. Can hear the fridge humming along . All the sounds are the...
looks like a blocked evaporator. 1st course of action would be to carry out a 48hr total defrost... signs are external frosting on rear panel at the bottom of freezer unit behind shelves or drawers...
Dec 18, 2009 | Whirlpool Refrigerators
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
I HAVE A GE PROFILE REFRIGERATOR TOP FREEZER, MODEL# TBX22PAYMRAA THERE IS ALWAYS WATER ON THE SHELVES AND A LOT OF WATER ON THE BOTTOM UNDER THE VEGTABLE BINS. WHAT IS CAUSING THIS AND HOW CAN I FIX IT?
Two separate problems here.
One; remove the ice maker, then remove the back panel from the freezer. The defrost drain is probably frozen . It will have to be thawed. Then run a 1/4 cup of bleach through it.
Two. Water on the shelves sometimes is caused by the frozen drain line referred above.
But can be from a poor door seal on the fresh food compartment.
Check the sides and bottom of the door seal. It may have pulled loose from the plastic liner.
If it is warped and damaged it must be replaced.
Feb 23, 2009 | GE Refrigerators
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Whirlpool EL7ATRR Refrigerator Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
