Question about GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven - just stopped stopped working
GE Spacemaker XL1800 over range microwave. No lights/clock/nothing. Replaced two 250V 20A fuses located near end/start of power cord with absolutely no change. dont know what to do next. any help is welcome.
  • Anonymous Jun 05, 2008
    I attempted to cook something for 7 minutes and it stopped no light, no vent, no microwave. I had a plate and potatoes in no rack. I did get an angry spouse out of this but that is all.
  • sweetraby Oct 07, 2008
    the microwave is spacemaker xl1800.and i had a problem when i tried microwaving a cup of water everything on and in the microwave just stopped working.pls help me
  • GE Master
  • 9,086 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Links no longer work
Posted on Oct 14, 2012
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 all working, not heating
Your magnatron tube is junk, you can get it replaced by a repair place, but if your microwave is not an expensive one, you may want too just buy a new one, mag tubes genraly run around $70.00 and up
May 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not work
please dont forget to rate me on this issue...
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Micro stopped working
Try looking at the microswitches behind the door.
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,873 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
