Question about APS787N Advanced Remote StartKeyless Entry and Security System
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
  • Audiovox Master
  • 625 Answers
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Posted on Oct 14, 2010
Alarm remote not functioning properly, no valet switch.
i would think the button is activating the fob, or when you put new battery in is it the right way or you may have pushed something inside and its come lose off the board, it would need opening up and having a look, and testing the switch.
Jun 10, 2017 | Audiovox Prestige Code Alarm Remote Alarm...
Remote start starts car and dies off after few seconds
try having the cpu reset using a code reader as you may have two systems operating in conflict that is causing the problem.
Jul 29, 2013 | Audiovox Prestige APS997C Alarm/Remote...
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My alarm was working fine then one day i just unlocked the car drove then when i tried locking the car with the remote and it didnt work the light that flashes when alarm is on didnt start flashing it...
Sounds like the unit may have seized (common occurence with this unit). Disconnect the positive battery terminal, wait ten seconds, reconnect. If you have a security radio be sure to have the code handy.
May 22, 2011 | Brand New Prestige Aps787n Remote Startcar...
Bought a car that already had the prestige remote. I cant get the trunk button to pop my trunk. Any sugestions??
The function requires that the vehicle have a power trunk release. If the vehicle has a power trunk and, the system was wired properly; press and hold the green trunk release button for approximately four seconds. If it's an option button, the same time is necessary.
Apr 25, 2011 | Prestige Remote Start
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
Prrestige Car alarm
press function (f) on your remote and Unlock at the same time for one second. as long as you have the two way remote it will work
Dec 16, 2009 | Car APS997A Two-Way Remote Start and...
Transmitter no signal
check you setting or rest and start programming over
Jul 01, 2009 | Vehicle Parts & Accessories
How do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Mar 13, 2009 | Prestige Remote Start
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
APS787N Advanced Remote StartKeyless Entry and Security System Logo
361 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
