Question about JVC AV-27950 27" TV
I turn the tv on and it does not come on. If I slap the side of it a few times, it will come on.
  • 998 Answers
It has a weak solder in the main board power supply part try to locate a weak solder it is visible then resolder it be sure to unplug your tv before doing that.
Posted on Oct 13, 2010
Blinking red light at power button if you slap the set it will come on but any movement will turn the picture off and the blinking light back on
this is a dry canaction problum in pcb do not slap tv.
* cont. tv tech. nr. at your home solve this problum in fuw mint. it is not expanciv but. if you slap tv then posibal spear damage in inside tv.set.and he is very expanciv.
Oct 31, 2009 | Toshiba 36A50 36" TV
Does anyone have instructions for getting at the lens mechanism? I totally understand the risks of doing this myself, but the cost of getting a shop to do this is nearly as much as a new camera! I am sure...
I guess , lens got damaged; if that is the case you need to change the lens and its very complex process.You need it to get repaired from authorized shop.
Aug 21, 2009 | Olympus FE-280 Digital Camera
When I turn off tv, it won't come back on for days at a time
this is going to sound strange .
Slap it open hand firmley on the side if comes on
its bad solder ,
Jun 30, 2009 | Televison & Video
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
It won't allow tape !
I had the same problem with my ZR200. It would not accept the tape, even a new one. I happened on this site and read about 20 comments from people who had the same problem. They all solved it the same way. You close camera's LCD screen and turn that side face down. Next you place your left hand under that side, close your right fist and gently slap the top side(cassette side) of the camera with the bottom of your fist. It worked for me the first time and now works GREAT! I had called a repair shop who told me to bring it in for repair and then I was looking on the internet for a replacement camera when I happened upon this site. Yes, I do believe in miracles! Good Luck.
Jul 10, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200 cassette loading
reading other threads here the soloution that works, yes for real, slap it on the tape side (closed) a few times then try to reload the tape, if it doesn't work the first time, close it and try slaping a few more times. I had to do it a few times but it does work.
Mar 28, 2008 | Canon ZR200 Mini DV Digital Camcorder
Door will not open on dvd player
Is there a "lock mechanism" that will need to be undone?....accordianman
Jan 19, 2008 | TruTech TT320
Set needs to be slapped to get a picture
TV's need a good slap once in a while to set them right! Just kidding. Sounds like you have a bad connection that once the set is warm it mends itself. Have a technician look at it.
Apr 18, 2007 | Toshiba CF27H50 TV
JVC AV-27950 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
