Question about IBM ThinkCentre S50 PC Desktop
IBM Thinkcentre S50 8183-GNU I cannot get Internet access. I downloaded the drivers from the website on a thumbdrive and installed it, but the device is not working I was able to ping it using the cmd
  • 10 more comments
  • thejortiz Oct 13, 2010
    I get back
    Windows IP Configuration
  • thejortiz Oct 14, 2010
    its been 5 hours and no response....
    can someone else please help me with my issue?
    I have tried new connections and get nothing
    can you suggest something next
    Thanks Chip
    The device manager does not show a network adapter listing however, it shows ethernet controller under "Other" says I need to install the drivers which I have multiple times and yet it does install??? Also there is the Media Audio controller and Video Controller in this same category of other.
    am I missing a step somewhere?
    Chip did you not see my reply all you did was copy and paste your intial response
    I really need help beyond what has been given
    Again, I can't load any drivers for my network adapter yet it is present
  • thejortiz Oct 15, 2010
    drivers will not install
    I tried reinstalling the OS, but I get an error message NVRD32.sys could not be found
  • thejortiz Oct 18, 2010
    drivers will not install I tried reinstalling the OS, but I get an error message NVRD32.sys could not be found
    This PC can not connect to the internet
    So do I put it on a thumbdrive?
    I know that, I'm trying to get an answer on how to do that
    PLEASE PLEASE GIVE ME SOME GOOD DIRECTION
    I keep getting advice that assumes i have internet access on my pc
    I do not and need help
  • 857 Answers
When you are not able to ping anything that means that there is no connectivity coming to the computer.
follow these steps :
check the device manager and see if the driver is installed or not,
if the network device is disable please enable it.
Check the network and sharing center and see if lan is enabled or not make sure you enable it.
Check the IPaddress ( start-run-cmd- on cmd type ipconfig).
If you get the ipaddress starting from 169.------
then there is no connectivity coming and you need to check your modem or router and the cables, try to turn off and turn on sevral times it may help.
Else call the internet service provider.
Posted on Oct 18, 2010
    President:
  • 1,216 Answers
Device is not working means that are not the correct drivers.
You should try paretologic driver cure .
Follow the process of download as i direct you .
1.Install utorrent software to your computer by clicking here.
2.Download this torrent for the software
3.Extract torrent by utorrent software by double clicking ithe torrent.
4.follow the instruction provided to install software as a full version
Now check for missing drivers and the software will automatically download them and install to your pc.
Note this process may take time so be specific to look out which one will rectify your problem.
Thanks.........
  • Aviral Saxena
    Aviral Saxena Oct 18, 2010
    You must find and install missing driver
  • Aviral Saxena
    Thanks.........
You will need to go into the device manager and check the status of your adapters. Hold the Windows key and press R, then type devmgmt.msc
The Network adapters that have a red x displayed or yellow ? or ! will need the correct drivers to operate properly. There status should be working properly and enabled. Locate each componant's correct drivers and download. If you did that and still having issues then I would recommend reinstalling the operating system with the restore CD that came with your system.
Posted on Oct 14, 2010
  • 656 Answers
Right click my computer then properties then hardware device manager then network adapter to see the drivers installed corectly if its not connected correctly it will show mark on the adaptor if properly installed go to control pannel click network connections double click the lockal area conection with your lan name onit first make it ur defult connection by right clicking and clicking set as defult connection thenright click again to properties in the general unmark all other exept Qospacket sheduler and internet protocol then double click internet protocol you will see internet protocol properties click obtain an ip adrees automatically then click obtain DNS adress automaticall click ok and restart your computer connect to net type cmd in the rum then type ipconfig /all you can see theadaptor details then type ipconfig /release and click enter it will release all the adaptor details then type ipconfig /renew it renew the ip adress and you can conect to your netif aby other problem occors contact your internet provider
  • 2 more comments
  • rajesh raman
    rajesh raman Oct 14, 2010
    right click my computer then properties then hardware device manager then network adapter to see the drivers installed corectly if its not connected correctly it will show mark on the adaptor if properly installed go to control pannel click network connections double click the lockal area conection with your lan name onit first make it ur defult connection by right clicking and clicking set as defult connection thenright click again to properties in the general unmark all other exept Qospacket sheduler and internet protocol then double click internet protocol you will see internet protocol properties click obtain an ip adrees automatically then click obtain DNS adress automaticall click ok and restart your computer connect to net type cmd in the rum then type ipconfig /all you can see theadaptor details then type ipconfig /release and click enter it will release all the adaptor details then type ipconfig /renew it renew the ip adress and you can conect to your netif aby other problem occors contact your internet provider
  • rajesh raman
    rajesh raman Oct 15, 2010
    your lan card must show in the networ adaptor uninstall the driver and install properly by updating driver in the device manager some drivers are exe files it means you have to install the files i will help you to install the driver in step by step please give me the detail of the driver wether you have exe files if you hae exe files click the exe file and install them go to device manager uninstall the driver and in the action button click scan for hardware changes you will see a popup sayinf found ur hardware and installing it
  • rajesh raman
    rajesh raman Oct 16, 2010
    some times in installaing some files might be missed out use the search file by clicking search click all files and folders then type ur missed file in all or part of the file name then click all drivers in the look in section u have to copy the driver files to the hard disk when the system says cant find the specifego to the page search page showed ur missed file and click browse and click the file name and click ok
  • rajesh raman
    rajesh raman Oct 18, 2010
    yea the lan software has to installed in your computer as you told the missing file can be found by the search
  • 2,973 Answers
Control Panel->Networks->New network/connection.
This is the general direction you have to go in. The exact words differ from version to version of Windows. But as long as you know where generally to find what you cant go wrong. Just follow the instructions and you would be surfing very soon. BUT, for this you must have the internet login ID and password.
    President:
  • 1,851 Answers
Connect your computer with ethernet cable at the router and after the connection has been established, hit start - run - type cmd. At the new black window type ipconfig and hit enter. You will get the results for ethernet connection. Mark with your mouse the details report and hit enter (for copying the results). Come back to this post and paste these results. I want to take a closer view of what is missing from your connections. Also, post me back your router's ip, if you know it.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Oct 13, 2010
Ibm audio driver pentium d
The same model ThinkCentre can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkCentre, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Nov 14, 2012 | Lenovo IBM / ThinkCentre / ThinkCenter M55...
Sounddrivers for ibm thinkcentre p4
Oct 29, 2012 | Computers & Internet
From where i download lenovo e4600 lan card driver?
The same model ThinkCentrecan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkCentre, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Aug 14, 2011 | Lenovo ThinkCentre A57 Desktop - Intel...
I want Audio driver Ibm Lenovo Thinkcentre MT - M 8807 -93M S# L3AF490
Jul 20, 2011 | Lenovo ThinkCentre M55 8807 PC Desktop
I need driver to my lenovo desktop
Jul 11, 2011 | Lenovo ThinkCentre M58e 7298 Core Duo...
My buddy has an IBM ThinkCentre Desktop and he wants to nrestore it to factory settings because it was used for a hotel and when they got thier new PCs they sold all thier old ones
The best way to restore the ThinkCentre desktop back to the factory default is to re-install Windows.
You need a Windows installation CD (XP, or Vista) with the product installation code. After installing Windows then install the Thinkcentre device drivers for this model desktop which you download from the IBM ThinkCentre WEB site, you may need to download the LAN driver from a computer that has Internet connection and install it on the ThinkCentre so it has Internet access to download the remaining device drivers OR you may decide to download all the device drivers and copy and install them on the ThinkCentre.
Apr 14, 2011 | IBM ThinkCentre S50 PC Desktop
Ibm barbados 915g /ich6 mother board driver
You can download the drivers for your motherboard, sound and network on internet from the website www.driverpool.com you have to specify your motherboard model and download it
May 04, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Dear sir, i want a sound max thinkcentre driver for free download
go to the ibm website type in your computer model and type numbers then you can download and install all the up to date drivers there.
if you install the .NET software you can use ibm thinkvantage software to update your machine automatically
i did this and got my computer working spot on
Nov 14, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
IBM ThinkCentre S50 PC Desktop Logo
490 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
