Question about PNY 2GB microSD Memory Card
Which way is the lock on the card? up or down
    Sergeant:
    Champion:
  • 289 Answers
First you need an adapter for this: which way is the lock - aed9005.jpg
After you have an adapter, it will have markings on it for you to push up the white slider, which will push a mechanical slider inside the microsd card to unlock itself. You can't do this by hand because it pushes a metal contact inside the card itself. If it is still locked, try plugging it into your computer and use a locking program.
Simple Terms: If it is a normal card, push towards the arrow to unlock, push away from the arrow to lock.
Posted on Oct 13, 2010
It says memory card locked
AYou didn't specify what type of memory card you're using so I assume you're using an SD or SDHC card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 19, 2013 | Cameras
How to remove write protection from my sd card
While looking at the front of your SD card, the label on your card should have "lock" printed on the left upper corner of the label. On the left side of the card should be a very small tab. If the tab is closest to the top of the SD card, it is unlocked. Likewise, if the tab is closer to the middle of the card, it is locked. The tab slides up and down; up is unlocked and down is locked. Hope this helps!
Jan 01, 2011 | SanDisk 2GB microSD Memory Card
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 | HP Cameras
My memory card is locked
Good day!
Locked..You mean write protected?I think there are instructions on how to unlock it.
Anyway, Try this:
There is a slide unlock/lock switch in the side of SD card. Its up and down switch that on and lock the card.
If you're using a mini card try to insert it to standard SD adapter.\
regards,
Mastergani
Jul 06, 2010 | SanDisk 1GB microSD Memory Card
Memory card is locked. Where is the lock?
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
Mar 02, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
THIS MEMORY CARD IS LOCKED, PANASONIC FS42 SILVER/ARGENT
Have you tried the camera with another SD card, to see if the problem persists? (A reputable photo store will often lend you a card for the 20 seconds it takes to do this test).
Feb 27, 2010 | Panasonic Cameras
Card is locked. Cannot find a slide on the side
On the left side looking at the front of the card. very small, up is unlock, down is locked.
Nov 24, 2009 | SanDisk 2GB microSD Memory Card
My vivitar camera when openned staes card locked how do i clear this
on the left side of the memory card there is a lock switch. if the switch is up, its not locked. if the switch is down, its locked. theres also another type of sd card when theres a tiney memory card that goes in the bigger one. take the tiny card out and its locked. put it in and its unlocked. did i help?
Oct 09, 2009 | Cameras
Card lock, how do i fix it?
Take out the memory card look on the left hand side of it and it might say in little letters lock and there's a little thing that moves up and down and then move it up.
Jul 22, 2009 | Canon PowerShot A540 Digital Camera
Camera Says "Card Locked"
It seems you need to open the camera and check the SD card slot.
this tip may help you How to fix a ‘card locked’ problem
Jun 01, 2009 | Pentax K100D Digital Camera
PNY 2GB microSD Memory Card Logo
61 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
