Question about LG 32LG30 32 in. LCD HDTV
Problemas de encendido tv lg - LG 32LG30 32 in. LCD HDTV
  • 11,361 Answers
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=32LG30&kategoria=tv&kat2=all
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 13, 2010
Booting fail
hola engo el mismo problema de booting fail he optenido ecte nas en ebay con dos discos de 1tb y este no funciona he echo casi todos los pasos del manual de instalacion precionando el boton de encendido mientras preciono el boton de flecha derecho e izquierdo entra en modo netboot y hay logro configurar la ip en el siguiente paso con el programa nas etector me dice que actualice el firware,pero no tengo forma de hacerlo ya que para ello tengo que tener acceso al nas y no puedo de ninguna forma gracias a quien ayude a solucional este fallo
Feb 01, 2013 | LG N2R1 - NAS server (S7636797) Network...
Engine backfires
problema de encendido carro pontiac gran amse 2002 aparece alrma de segurity de encendido
Oct 17, 2012 | Cars & Trucks
Se enciende en tablero el foco de ABS y Track Off
Sugiero escanear los codigos de fallo del modulo ABS, solamente con estos codigo podremos diagnosticar y resolver el problema.
Jul 21, 2012 | Cars & Trucks
Problema de encendido de nissan altima 2.5 del 2003
hola quisiera saber cual seria el problema de mi carro es un Nissan 2002 Altima le canbie de motor y prende muy bien pero cuando lo paro ya no arranca moja las bujillas y ya le canbie los sensors de ciguenal y del arbol de lebas y los inllectores y sige asiendo lo mismo
Mar 18, 2012 | 2003 Nissan Altima
Tengo una pantalla de 37 de tft samsung a la que conecto la ps3 por hdmi hasta hora sim problemas hoy la he conectado y me sale modo no compatible que es lo que puede pasar,e probado la ps3 en otra...
Puede ser que se haya desconfigurado el ps3, en caso de que sea este el problema, no desesperes que la soluci?n es muy f?cil. Conecta tu ps3 a tu tv a trav?s del cable hdmi, ahora, cuando enciendas la consola, deja oprimido el bot?n de encendido por unos 5 segundos, esto resetear? la configuraci?n de video de la consola y esta se ajustar? autom?ticamente a tu tv, presiona (X) cuando la interface te lo indique. Si esto no lo soluciona, y la consola funciona en otros tvs, es otra la situaci?n y es probable que tu tv este fallando.
May 05, 2011 | Sony Playstation 3 (PS3) Console
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
No le funciona el encendido y las funciones, solamente lo puedo hacer desde el control remoto, sera que es problema del aparato o alguien lo bloque con alguna tecla
hola,
Si hace poco empec? a hacer esto, y funcion? bien antes, entonces no es probable que sea un error de cableado. Es posible que tenga una unidad principal defectuoso.Tambi?n es posible que usted tenga un interruptor de encendido defectuoso. Pruebealgunas funciones accesorias otros.
por lo que sugiero a usted para cambiar el interruptor de encendido.
Espero que esto sea ?til para ti.
por favor no te olvides de votar.
goodluck
Jan 21, 2011 | Sony Audio Players & Recorders
Tengo el problema q de mi portatil extensa 5230 series el encendido de la pantalla y el encendido del teclado me han quedado inutilizados, y no me deja utilizarlos en modo normal pido por favor un concejo...
Primero, se prende su computadora normalmente? Que hace su teclado cuando la computadora esta prendida? Hay algun error que aparece un su pantalla? Desde cuando tiene este problema? Installo algun programa antes de que pase este problema??
May 17, 2010 | Acer Computers & Internet
LG 32LG30 32 in. LCD HDTV Logo
191 people viewed this question
Computer Repairing
Computer Repairing
