Question about John Deere 54 in. EZ Trak Power Flow Blower Assembly
Where does the tension spring attach in the blower for the JD 54" power flow blower assembly?
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
Craftsman 316794990 leaf blower. I have a problem
Lakeviewpower dot com here is a link to my website. Call me on price and avilibility. Part number mc 9228 320602. Mtd model number 41ar322g799 1 972 475 9946
Nov 21, 2009 | Craftsman Blower Attachment
Rope won't recoil. i can jiggle it back in.
Clock spring either broken or un-hooked in inside of pull assembly. you have to take it apart and either re-attach spring or replace spring. Interior of assembly shoul;d be available on-line. You should have model # available.
Aug 21, 2009 | Toro Lawn Mower With Toro Power Tools
Excessive Grass
the grass is too high, cut it 2 times first cut should be half then the second cut should be the normal level. just remember go the other way on the second cut.
Aug 28, 2008 | John Deere 48 in. EZ Trak Power Flow...
John Deere 54 in. EZ Trak Power Flow Blower Assembly  Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
