I PURCHASED A HIGH-SPEED USB 2.0 DRIVE. I TRANSFERED ABOUT 30 FOLDERS OF PICTURES ON IT. IT WORKED FINE, TIL I PLUGED IT IN AGAIN AND IT SAYS THE FOLDER IS EMPTY. WHAT MUST I DO TO RETREIVE MY PICTURES?
    Scholar:
  • 141 Answers
Hi holly21831;
you may try it on another pc,just to see if you get the same problem, it may be a faulty USB but try it out first.
Posted on Jun 03, 2008
Transfer pictures from tablet to computer
The simplest way is to use a usb flash drive or an external drive. Simply plug it into the tablet and open it once the computer recognizes it. Create a folder on the USB Flash or External and call it TabletPics for example. Then go to where the pictures on the tablet (probably in my documents or my pictures). You can copy the one picture from the tablet by highlighting it then right clicking on it and select copy or you can select Edit then copy at the top of the window where the pictures are. Then go to the usb flash drive or external drive and paste them by selecting Edit Paste or by right clicking anywhere within the Folder we created called TabletPics and select Past.. If you have a lot of pictures you want to copy you can try clicking on the first one you want to highlight it then go down to the last one you want and press the Shift Key and hold it while you Click on the last picture you want. It will highlight every thing you selected then you can copy them as we did before with the one picture and go paste them on the usb Flash Drive or External Drive in the Folder we created called Tablet Pics.
When you are done copying the pictures to the usb flash drive or external drive from the tablet, remove it and go plug it into the computer you want to put them on. It's the same process you will be copying pictures from folder TabletPics on the usb or external to a folder on the computer. Actually you can just copy the whole tabletpics folder by clicking on it and then Paste the whole folder on to the computer in the My Pictures folder.
Mar 21, 2012 | IBM Computers & Internet
Transfer rate is too slow 1 - 2 MBPS write speed read speed is ok in USB 2.0. I formatted the drive using storejet and then the wite speed moved up to 15 - 20 MBPS. after copying 2 folders it again dropped...
I got exactly the same problem with my Transcend Storejet 25M2 500GB hard disk. Formatting didn't helpw much and specifically the write speed is very slow, formatting improved the read speed though.
May 16, 2011 | Transcend 640GB Transcend StoreJet 25D3...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
When uploading pictures from my cameras SD card the computer suggests using a hi-speed USB port. I have tried the other ports and it tells me the same thing. Which port is the High speed? Dell Dimension...
you have no high speed ports installed on your computer. what you have is USB 1.0. you can however purchase a high speed USB pci card (usb 2.0) and install it in your computer to get faster transfer speeds.
Jun 11, 2010 | Dell Dimension 3000 PC Desktop
19111 how do i transfer photos from pc to usb drive
If you can access the usb drive you can just drag the photos from your picture folder to the usb drive folder. Make sure to make a folder on the usb drive first. It works just like any other drive.
Oct 26, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
I want to transfer data from my dial-up desktop, to my new laptop high-speed broadband. How?
Several ways:
1.) 4GB flash drive
2.) External USB drive (320GB or more)
3.) Burn CD or DVD on the desktop and copy to the laptop
4.) Connect them in a local or ad hoc network (not too easy)
I'm sure other expers will have more ideas...
Anyway, at the desktop, run the "Files and Settings Transfer Wizard" to gather your desktop info, such as favorites, desktop icons, My Documents, etc:
[Start]
[All Programs]
[Accessories]
[System Tools]
[Files and Transfer Wizard] [Next]
At the desktop, answwer [Old Computer] [Next]
Cintinue to answer the questions
If you have a lot of music or loots of pictures, then just transfer the "Settings Only".
After a successful transfer of the settings, run the wizard again and transfer your "Data Only"
Hope this gets you started.
Sep 18, 2009 | Computers & Internet
I have several pictures on my computer on Kodak Easy Share. I purchased a Toshiba USB 2.0 8 GB flash drive to transfer the pictures to the flash drive but can't figure out how to use it to transfer the...
Just plug the flash drive in and let your computer recognize it and offer to open the flash drive file up to view. Once it is loaded up then you can simply drag and drop into it. If this is the first time using the flash drive it may need to load some software. When a flash drive is being used a small icon should appear on the lower right.
Sep 08, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Can't download pics onto PC
re instal the driver as it may be corrupt, or simply go to my computer, right click, explore and you should see your camera as a drive, right click it>explore and then there will be folders same name as the camera>explore and the pics will be in there, select them all slect cop, then go to the folder you wish to kepp them in and select paste.
Aug 29, 2008 | Nikon COOLPIX L10 Digital Camera
I'm trying to transfer pictures frome Kodak Easy Share to the drive so I can have more space on my internal drive. I also want my music to be transfered. I'm the problem because i am not great at...
If you have your music and pictures on one hard drive, and transfer it to the external hard drive connected by usb:
1) Connect external hard drive
2) Select the files you want to move.
3) Right click on one of them, and choose cut.
4) Go into the external drive, and choose paste. (They will start to move over.
5) To see pictures, you will right click in the picture folder and choose view. Select large icons. That should work. Also you could choose view from the top, and select pictures.
Aug 12, 2008 | Computers & Internet
I purchased a western digital 160G external storage device. My computers tell me that it will be slow without a high speed USB port. However, I get a prompt to install software or to insert a disk into...
use windows xp service pack 2 professional
all the ports are then usb 2 .
if this doe not solve the problem change the circuitry of the ext drive on which you mount the hdd
Jul 09, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
