Question about Ashton Digital (WRCB-1011R) Wireless Adapter
Change of encryption key
I recently changed the password & encryption key for the router of our domestic wireless network. Now my laptop fails to connect even after the new encryption key is entered (AirDash WRCB-1011r). What could be the problem?
    Problem Solver:
  • 18 Answers
Connect a cable from the router LAN port to the ethernet port on the system.
Check whether the internet is working.If yes
Click on start RUN & type in cmd
Then type in the dos windows the following command ipconfig.
Look for the IP address something like 192.168.x.x or 10.0.0.1etc.Open internet explorer & type the IP address from the above step in the address bar without the http or www . it will open the router GUI .It can ask you for the username & password depending upon the router model.Please let me know.It could be anything .try some of these.admin blank,blank means leaving it blank,or blank admin,or admin password ,If it opens try finding the wireless settings(advanced)Look for key 1 : That will be the key which you need to put in .Let me know if it works.All d best
Posted on Jun 06, 2008
Changing network password
You can change your wireless encryption to protect your wireless network from unauthorized access.
Connect a LAN cable from Belkin to yourlaptop/computer's LAN port, open a browser on your laptop/computer and enterthe Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings.ie. SSID (wireless network name) WPA or WPA2 encryption key.(wireless protection).
Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 02, 2012 | Belkin Basic Wireless Router
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
Hey ! I've got a DELL Wireless 2350 Broadband Router and it's working just fine. Recently I purchased a wireless printer (Samsung ML-1856W). I get the printer to work via the network if I...
My first thought would be to try different forms of encryption on your router. It's possible that your printer may not support the type of encryption you're trying to use which may be causing it to have trouble connecting. For example, if you're using WPA encryption, try switching to a WEP key instead. You can change all of these settings from your Wireless Router's configuration page.
Jul 24, 2011 | Dell Wireless 2350 Router
The router works fine for connection with my desktop to my laptop, but when I try to use the wi-fi connection with another device it says that a password is needed and I do not know where to look for the...
The password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
Dec 26, 2010 | D-Link DIR-615 Wireless Router
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
Can't locate my security key. trying to allow a visitor to use my router
My suggestion is change your password/security key.
http://192.168.0.1/
Then log into your router, username: superuser or admin password: password
That is the default, if you change it, I can't help you there and you would have to talk to your internet provider to change it for you.
Then there should be something like "wireless setting" check your options and it should ask for something like "SSID". If your on something that says that your on the right page. Find something like "Security Encryption" and change your password to something you will remember.
By doing this your visitor should be able to connect your encrypted wifi. But also doing this you might need to reconfig your laptop/desktop to the new setting.
If your using Vista:
Start > Network > Network and Sharing Center > Manage Wireless Network > Highlight your Wireless connection ( Select Remove) > Add > Then go through the process of finding your wireless connection and you magically got back your protected wireless again on both laptops.
Hope this helps you.
Sep 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
Not prompted for network security key
Sir,
Under 'preffered networks', which can be found on the Wireless networls TAB in advanced settings, you will see your network there. Click on it and then hit properties. Under the 'Association' TAB, you will see network authentication, choose WPA-PSK or WPA, but I will imagine that your key is a Pre-shared key. Enter it there. Data encryption will be TKIP and not AES. Go to connection TAB, and make sure the box is checked in that section. If these steps fail, then you can always change your encryption to WEP. You can do this using a computer which connects to your internet through the WPA key. Once connected on that PC, open up command prompy using the command cmd in the RUN box when you click on the START TAB. A black box will open, simply type ipconfig and look for "default gateway"...it will have a number with a few dots, like this one: 192.168.1.254.....etc. Enter this code into your internet browser search bar, and hit enter. Your internet providers interface will show up, you can find a tab which will have something to do with wireless security, and there you can change the WPA to WEP, with a WEP key of your choice. If you are prompted for a password then you should know it! Sometimes, the usernames can be simply 'admin'. If you manage to change your security to WEP, you can use your laptop!
All the best.
Jan 01, 2009 | Linksys Wireless-G WRT54GS Router...
Finding encryption key
This should work give it a try:
1)go to control panel
2)click on internet connections
3)wireless network setup wizard
4)click next
5)set up a new wireless network
6)next
7)Automatically asign a network key
8)set up a network manually
9)print network settings
Dec 21, 2008 | IBM ThinkPad T40 2373 Notebook
Ashton Digital (WRCB-1011R) Wireless Adapter Logo
73 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
