Question about Roper REX4634KQ Electric Dryer
My Roper dryer heats up but does not turn when I push the start button. What would cause the dryer to not spin?
  • 1,531 Answers
One is the belt may be broken or have slipped off the pulley.the door switch could also be bad. try and hold the door open and depress the door switch at the same time someone is pushing/turning the start button and then try to rotate the drum be hand and see if it will turn. the motor could have alot of lint build up and cause the motor not to turn.
Posted on Oct 13, 2010
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
I push button to turn on it starts to turn that fan with a loud noise then sometimes starts then shuts off after a few minutes..please help me..its a roper 5 cycle electric
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Roper REX4634KQ Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Roper dryer has power I can here it, but it does not spin the clothes dry...doesn't turn on. How do I figure out what is wrong?
try this,open the door,with one hand push in the door switch,with the other hand spin the drum,have someone else push the start button,if it runs you have a bad motor
Feb 22, 2011 | Roper REX3614KW Electric Dryer
Roper dryer model REL4434AWO has stopped spinning. Heating element works. Belt seems secure around drum.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 18, 2010 | Roper Dryers
I have a roper dryer .the dryer will just hum when you push the start button and will not do anything like its is in a bind . the humming occurs only when you have the button pushed , its like it don't ...
heatman101
Oct 27, 2010 | Roper REX3614KW Electric Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer
Hi thanks for your question. When a dryer growles at you like that. Its a sign of a bad motor. To repair the dryer replace the motor
Oct 28, 2008 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
89 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
