Question about Maytag Neptune FAV6800AW Top Load Washer
Stops will not spin had censor replace still will not spin.
  • 526 Answers
Is the wash tub banging around in Spin Cycle with a wash load then failing with a dC or UC unballance error code?
If so the TDS is working as designed. Try a Spin Only cycle with no clothes in the wash basket. If it completes then the issue is most likely a clutch malfunction of your FAV6800A or FAV9800A machine. See this post Clutch Fix
Did you replace the TDS sensor or did a repair person? If it was a repair person did they try a Wet Load Spin Cycle after the TDS replacement?
If a repair person was called and the TDS replaced what troubleshooting steps did they take to warrant changing out the TDS? I would ask if the range of montion check of the TDS was checked for properation signaling action to the Control Board in Service Mode.
Posted on Oct 13, 2010
Timer Stops Cycle
That depends. Is the machine only stopping during the spin cycle? If it has a water pressure backwash censor then you might need to take a look at the plumbing for water leaving the machine. If it does not have this problem, I recommend replacing the timer assembly again.
CH
Jul 30, 2008 | Frigidaire FTF530FS Front Load Washer
Saturn Ion Problems i have a 2005 ion 2 the car is overheating when stopped in traffic temp gage rises when i move it drops back to normal i have replaced the fan and the censors and still have the same...
check that the direction of the fans is correct as with DC power fans if the polarity is reversed then the fans will spin backwards . Check that the fans were correct type for your car. The problem is no air flow through the radiator at idle which is fan problem
Sep 23, 2013 | Cars & Trucks
I REPLACED O2 CENSORES AND THE MAF CENSORE
Check wiring, animals love to chew them.
May 19, 2013 | 2000 Nissan Xterra
My 96 ford explorer runs, when driven often drops rpms when I press my accelerater. And my engine will just die. replaced the mafs, o2 censors, ecgr feedback value, throttle position censor, fuel filter...
stop changn parts til u kno the cure--probly dirty idle air motor--a worn distributer cap-inside--or a hidden vacuum leak-------get car scanned
Jun 04, 2012 | 1996 Ford Explorer
Ps2 slim disk wont spin and it doesnt read anything it just says there is no data
yes you have a bad laser pick up censor . now you can try to clean the laser by open the unit or buy the laser (pick up censor) and replace i have fix many of this unit and by cleaning never work tha price on the part $50 to take it to a repair shop may be to fix it $90
Feb 02, 2011 | Sony PlayStation 2 Slimline Console
My washing machine is SANYO ASW-90WRTP. It cannot spin and showes E2 on the screen. I guess it means Error 2, but I don't know how to solve the problem. Thanks.
mungkin
  • barangkali
  • agaknya
  • ')" onmouseout="ht(this)">perhaps
    pintu
  • daun pintu
  • laluan
  • ')" onmouseout="ht(this)">door
    tidak ditutup
  • tak bersalut
  • ')" onmouseout="ht(this)">uncoated
    dengan betul')" onmouseout="ht(this)">properly or penapis
  • tapis
  • menapis
  • ')" onmouseout="ht(this)">censor
    in pintu
  • daun pintu
  • laluan
    gagal
  • kecewa
  • terkandas
  • ')" onmouseout="ht(this)">failed
    . menghubungkan
  • sambungkan
  • menyambung
  • ')" onmouseout="ht(this)">connect
    pendawaian')" onmouseout="ht(this)">wiring penapis
  • tapis
  • menapis
    with ( 2 dawai
  • wayar
  • kawat
  • ')" onmouseout="ht(this)">wire
    ) jika tiada
  • sekiranya tiada
  • sekiranya tidak
  • ')" onmouseout="ht(this)">if no
    dawai
  • wayar
  • kawat
    penapis
  • tapis
  • menapis
    menggunakan
  • penggunaan
  • gunakan
  • ')" onmouseout="ht(this)">use
    magnet
  • besi berani
  • batu berani
  • ')" onmouseout="ht(this)">magnet
    diletakkan pada')" onmouseout="ht(this)">placing at mengenai kawalan')" onmouseout="ht(this)">on control litar
  • lingkungan
  • peredaran
  • ')" onmouseout="ht(this)">circuit
    Nov 20, 2010 | Washing Machines
    Third Censor Broke!!!
    replase motor and ribben and get a lenz off ebay
    Nov 26, 2008 | Sony PlayStation 2 Slimline Console
    Cranks but wont turn over
    you know. i took it to a mechanic and actually.... The timing belt cut the Crank Shaft Censor... So it was the crank shaft censor again. The wires were routed wrong from the first mechanic that "fixed" the car.
    Aug 01, 2008 | 2000 Hyundai Sonata
    Maytag Neptune FAV6800AW Top Load Washer Logo
    95 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
