Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Water will not go into the washer if you pull knob out the hose isnt kinked
  • 1,531 Answers
Check and make sure that there is no sediment builkd up in the water lines if they are clear then you may need to replace the water valves.
the water temp selector switch may also be bad asuming that you have tried to use various water temps selections.
Posted on Oct 13, 2010
WHAT COMMON FAULT CAUSES THE PRESSURE WASHER TO CUT OUT WHEN PULLING THE SPRAY GUN TRIGGER
Lack of water preesue can cause this, how long is the hose to the washer, are there any kinks and what is your water pressure like generally.
If there are no kinks try shortening the water feed hose
Sep 13, 2014 | Garden
What happen is discharge hose is kinked
What you can try to do is fill the tub with at least a med. size load of water. The turn the timer to the spin cycle and stop the washer. while opening the kink with one hand and holding it, pull out the timer and drain the water. Sometimes the water pressure through the hose will open it back up. If not, then the hose will have to be replaced.
May 15, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
E 02 Error Message
There is a problem with the water supply. This could be a symptom of kinked hoses, clogged filters in the intake valve or low water pressure.
Turn off the water shut-off valves and disconnect the hoses from the washer and then the shut-off valves. Place a bucket under the hoses to catch any water that drains out of the hoses. Check the filters both on the washer and at the shut-off side of the hoses. Sometimes, you need to use needle-nose pliers to pull out the filters from the intake on the washer. Make sure that the hoses are not kinked when you reinstall them. You may want to replace the hoses. There are some hoses that will seal themselves if they detect a leak. This will slow the water flow to the washer.
While you have the hoses off the washer's intake, test the water pressure by measuring the water flow into your bucket when you open the valves.
Also make sure that the washer discharge hose is not below the washer's water level for your load size. This leads to the water flowing in and then out of the washer before it fills the machine.
I hope this helps.
May 05, 2012 | Bosch Classixx WFL 2066 Front Load Washer
GE washing maching not filling
Several factors can cause a GE washing machine not to allow water to enter the drum, including closed valves, kinked hoses, a faulty electrical breaker or sediment in the water lines. Sediment occurs most often when the water to the home is off due to electrical outages or when installing items in the plumbing. Cleaning the screens will remove a sediment blockage, allowing water into a washing machine.
    • 1 Check each water valve for the hot and cold water lines to make sure they are open completely. Open valves are turned completely to the left. Check the fuse at the electrical box to make sure it is not faulty, and check to make sure the washer is plugged securely into the outlet. Observe the water supply hoses to make sure there are no kinks from the supply valves to the back of the appliance.
      Observe the water supply valve handles to see if they are cracked. If so, they need replacing.
    • 2 Turn off both the hot and cold water supply valves. Turn each knob completely counterclockwise to turn them to the off position. Pull the washer forward to reach the water supply valves, hoses and the back of the washing machine. Place one hand on each side of the washing machine and slightly lift the front while pulling straight out from the wall.
    • 3 Place a bucket at the rear of the appliance. Use adjustable pliers to unscrew the hot and cold water hoses on the back of the washing machine. Turn each hose counterclockwise to unscrew and remove from the washing machine while pointing them into the bucket to catch any water in the hoses.
    • 4 Turn on the hot water supply valve and hold the hose pointing into the bucket. Observe to see if water is coming out of the hose or trickling out of the hose. Repeat this procedure for the cold water supply hose. Limited water or no water flow indicates that the lack of flow is at the valve end of the water supply hoses.
    • 5 Pull the filters out of the washer valves with needle-nose pliers. Rinse under warm water to clean out any sediment and replace them in the hot and cold water washer valves on the appliance.
    • 6 Unscrew the hot water supply hose from the valve using adjustable pliers. Turn the hose connector clockwise to unscrew and remove. Repeat this procedure with the cold water supply hose. Pull out the screen from each hose with needle-nose pliers and rinse under warm water to clean. Replace the screens.
    • 7 Replace both water supply hoses on the washer valves and the washing machine and tighten them with adjustable pliers. Slide the washing machine back into place and level the legs by slightly lifting the front of the washing machine and setting it back down.
Oct 03, 2011 | Washing Machines
My whirlpool washer will not drain the water.It seems to work fine at all other stages of the wash cycle.When it gets to the stage when it is supposed to drain it does not drain and you hear a buzzing type...
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Jan 10, 2011 | Washing Machines
Washer which is kenmore 80 series and about 6 years old just stopped working while filled with water. after 3 hours we finally got it to start again and then I stopped it cause it was filling up with...
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks
    Oct 03, 2010 | Kenmore Washing Machines
    I have a GE model# WLSR2000G2WW washer and it's not spinning out at the end of the cycle it started not spinning out when set on small load only now it's not spinning out on large load either. But if I...
    I found the hose hooked to the pressure was clogged down at the tub end. So it couldn't send a signal to the switch telling it the water had pumped out and it was time to spin out, the plugged hose was holding pressure telling the washer (falsely) that the tub had water in it so it won't spin if it thinks water is still in the tub. By pulling the hose off the switch end and blowing thru it to clear the lint and soap slime that was plugging the other end it works perfect now.
    Jun 13, 2009 | GE Washing Machines
    Washer stops after aggatating and wont drain
    My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
    Jun 10, 2009 | Whirlpool Washing Machines
    F H displayed on front
    it means no water is entering unit,,,check hot and cold hose,,,clean your inlet screen ..look for a kink in your hoses,,also check and make sure water is leaving unit,,if water isnt leave than ,,unit will not let water in ,,in case of an overfill..if you need help cleaning pump filter let me know...onthejob
    Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Our GE Profile Deluxe washer is not draining
    Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
    Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
    Jan 06, 2008 | Washing Machines
    GE Spacemaker Washer and Dryer Electric Laundry Center Logo
    29 people viewed this question
    Top GE Washing Machines Experts
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
