I had a Kitchenaid washer and is not finishing the sicle, what I egt is the code f-06 on the digital panel. I have aske this question all ready and no one had answer me yet?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 in your Kitchenaid indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you?ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
Water did not drain all the way out after last wash. Washer is now flashing F 06
the machine tined out on the pumping out thats fault 06 you have a blockage could be your filter / pump / outlet hose / sump hose / drain hose start with the filter
Nov 25, 2011 | KitchenAid KHWS02R Front Load Washer
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I turn the control knob to rince/spin, the machine froze
I believe the f06 is a clogged pump. You should be able to take off the bottom panel via 3 screws on the bottom of the panel. Inside should be 3 inch diameter white twist cap. Open it, but be ready with towels cause waters gonna come out. Thats the pump trap, it catches everything before hitting the pump. Hope that helps. Dave www.washermd.com
Dec 17, 2008 | KitchenAid KHWS01PMT Front Load Washer
Washer flashes P 2 and now SUD will not finish cycle
F-2 IS ERROR CODE SUD MEANS NOT USING H E DETERGENT,, REMOVE DEBRIS FROM PUMP AND SHOULD RESOLVES YOUR PROBLEM ,, REMOVE BOTTOM PANEL 3 SCREWS ONCE REMOVE PUMP FILTER RIGHT IN FRONT BE SURE TO HAVE ALOT OF TOWLES READY MACHINE STILL STORES 3 GALLONS OF WATER
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
CLOTHES COME OUT REALY HEVY AND WET AFTER WASH?
It sounds like the spin dryer is not working properly.
Oct 24, 2008 | Washing Machines
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
