Question about HP Color LaserJet 2600n Printer
Installed new black toner cartridge.............will not print, says that cartridge needs to be replaced.............what is the problem
May be catridge ink dry or not original catridge some difference model
Posted on Oct 13, 2010
  • alex1zach2 Oct 13, 2010
    brand new original hp cartridge installed
    any other suggestions?
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 20, 2015 | Office Equipment & Supplies
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
Thank you for contacting FixYa with your printer inquiry.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 30, 2011 | HP Laserjet P4015x Printer
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Printer not printing giving a black toner catridge not installed error and a new catridge is installed
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | Xerox Phaser 6110 Laser Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
HP Color LaserJet 2600n Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
