Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
MyBook's power light is blinking, but not showing up on my Mac's desktop
My MyBook Premium (320GB, FireWire) was working fine for about 4 months. But now when I plug it in, the blue power light comes on, but when I plug in the FireWire cable to my Mac, the hard drive never shows up on my desktop. Then the blue light starts blinking about once every 5 seconds. I don't know much about computers, but it seems like my hard drive is just not being recognized by my Mac even though its on. I contacted Western Digital support, but they just said to exchange it for another one. If that is my only option, what is the estimated cost for a data recovery service (I have about 10,000 songs and some video projects on it)? Thanks!
  • alenaraphael Jul 02, 2008
    I have the same problem; I plug in the USB cable and the computer brings up the window 'New Hardware Found' but then claims it can't find the driver. The WD drive says the driver is already installed on the drive itself, but it obviously doesn't work. I've tried downloading what I *think* is the right software from WD's support website but after installing it, all it wants to do is sync - which isn't what I'm after! I just want to be able to explore the drive so I can drag / drop files from my PC onto it. Why is this so difficult, what am I doing wrong?
Data recovery usually will cost about 2000 - 3500. i may be able to help as long as the platters aren't physically damaged. Send me the drive at your cost. I will pull all data and return data on burned dvds I keep the drive. If i can't retrieve data then i will return drive to you at my cost. jprusso@yahoo.com
Posted on Jul 09, 2008
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
HD does not apppear on desktop
I would disconnect it and connect it again.You probably will be asked to assign it a drive name like G-Drive or E-Drive.
Jan 01, 2009 | Western Digital WDG1C2500N MyBook Premium...
WD my book 320gb not responding
don't panic your hard drive might still be working . you say it dose not sign showing it's on. please have any cable that connect the hard disk to the computer checked. I think your cables might be bad.
thanks
Nov 20, 2008 | Western Digital 320GB MyBook External USB...
Have just bought a Verbatim portable hard drive (120GB) and it won't show on my Mac desktop. It works fine on my PC
Make sure your Mac meets these minimum criteria or it won't work.
  • Any Macintosh with built-in FireWire port or a Power Macintosh G3 with a powered PCI 6-pin FireWire adapter
  • Mac OS 8.6 to 9.x; Mac OS X 10.1 or higher
Sep 18, 2008 | Computers & Internet
Today my firewire bus powered mac mini 320GB external hard drive (that i bought this year) stopped being powered by firewire alone and needed the USB plugging in as well to be recognised and used...the...
Hi-
Chances are these large memory hard drive should be plugin with a USB and adapter of its own since 320Gb is too big and needs power to be able to recognize. But if you find it defective you have a year warranty from the manufacturer, you can call them up for a replacement.
Hope this help. Thanks for using Fixya!
Jul 16, 2008 | Computers & Internet
Drive is not recognized
Check if the Windows XP Security Updates are there on the Unit.
If these Update are present remove them & it should work Fine.
KB944533 - Cumulative Security Update fro IE 6 for Windows XP
KB943055 - Security Update for Windows XP
KB946026 - Security Update for Windows XP
Jun 17, 2008 | Western Digital 320GB MyBook External USB...
WD MyBook 320 GB Premium - Retrieving Data
You should buy a program called "Partition Table Doctor". I went through the EXACT same thing and it was just a bad partition on my mybook which is the EXACT same as yours is. It cleared up the problem for me. I still have problems with my mybook so i wish that I bought a different hard drive, but oh well.
but try "Partition Table Doctor", it will scan your mybook and fix any partition errors with it.
I was in the same boat as you over a year ago and trust me, "Partition Table Doctor" is a LIFESAVER!
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
2,434 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
