Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP7480 SKIPS PRINTING LINES HORIZONTAL ABOUT 1" SPACING
Soulvisitor
  • 1113 Answers
SOURCE: horizontal bands
Toner Cartridge. 98% Odds
Two inch's is the width of the thing causing you problems that thing is probally the drum, sounds like it might of been light exposed, anyway replace toner cartridge..
. if you remove catridge and gently turn over and slide back a black cover in centre you will find the suspect drum.
by the gears on the edge you can turn turn it gently one way it and you can get messy if you turn it the wrong way, part of the surface will of lost its colour a little.
Posted on Oct 16, 2007
SOURCE: black lines spaced about 2
Change the toner cartridge this happen with refurbished toner cartridges .
Posted on Nov 06, 2009
  • 223 Answers
SOURCE: For some reason my cp2025
There is no imaging drum in this printer there is only a transfer belt. It is the green film that is visible when you open the door. This sounds like there could be a problem with the dc controller take the printer to a local asp.
Al
Posted on Oct 01, 2010
  • 956 Answers
SOURCE: printer printing horizontal blue lines
Program malfunction, uninstall HP Printer programe and reinstall your version for the printer from www.hp.com remember to load the complete program.
Posted on Mar 24, 2011
  • 41 Answers
SOURCE: I just installed my new
This is the same problem. You need to run the cleaning cycle on the printer. Go to Control Panel > Printers > Select your Printer > Printer Properties > Maintenance > Clean Print Nozzles.
Please remember to vote for me if you like my solution.
Posted on Apr 07, 2011
Why are there Horizontal lines on copies spaced every 3 inches apar?
Download the following manual and check pages 1-293 through 1-308. The main problems with line on the page are do to (1) bad toner cartridge, (2) bad transfer belt and (3) bad fuser. If you want a more detailed explanation on how to get ride of lines let me know.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%203130cn%20Full%20Manual.pdf
Aug 13, 2014 | Dell 3130cn Color Laser Printer
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Skips about 1/2 inch of printing no matter what the document
Try this web site.
http://www.fixyourownprinter.com/forums/inkjet/15203
Mar 13, 2008 | Canon MultiPASS C755 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
