Hi I have a honywell termostat TH6110D1013 how can i swithc from fahrenheit to celcius. Thx
Press and hold at the same time the two buttons: FAN (bottom middle) and UP (top right) for a few seconds until the display changes and there is a 1 and 0? displayed...
the 1, the larger number on the left, is the "function" and the smaller number on the right is the "setting"...
Press below NEXT until you get to "function" 14 and then use arrows to change the "setting" from 0 aka `F... to 1 aka `C... press below DONE to finish.
Otherwise google TH6110D manual
Posted on Apr 06, 2011
How to switch from fahrenheit to celcius?
Best to just keep a conversion chart nearby...or label your gauge with Celcius...
Aug 23, 2014 | 1991 Buick Park Avenue
Tip
Refrigerator Tip!
Don't set your refrigerator's temperature too low. The colder it gets the more it costs to run. Set the refrigerator's temperature to between 38 and 42 degrees Fahrenheit (3 to 6 degrees Celcius) and your freezer to between 0 and 5 degrees Fahrenheit (-17 to -15 degrees Celcius).
on Aug 17, 2010 | Refrigerators
HOW TO REPAIR A THERMOSTAT
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
What dose 180 degrees Celsius Fahrenheit mean so I can bake
Hi Nancy,
180 degrees Celcius is about 360 degrees Fahrenheit.
Jan 29, 2014 | GE JKP30WMWW 27" Built-in Single Electric...
Change celcius fahrenheit
The easiest way of changing temperature from celsius to fahrenheit is getting it converted online.Check this link out: http://www.onlineconversions.org/
Jan 01, 2014 | Refrigerators
The temp reading is in celcius how do i change to fahrenheit?
From Celcius the formula is Deg. C divided by 5 multiply by 9 and plus 32.
From Fahrenheit the formula is Deg F minus 32 divide by 9 multiply by 5.
Feb 23, 2011 | 1996 Buick Park Avenue
What is the formula for 32degree celcius to fahrenheit?
the formula to convert degree Celsius to Fahrenheit is
Tf = (9/5)*Tc+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
to convert 32degree Celsius to Fahrenheit is
Tf = (9/5)*32+32 = 89.6°F
Jan 21, 2011 | Office Equipment & Supplies
I have a honeywell thermostat magic stat/32 model 3200. It reads celis and not farinheit. Just started doing this.
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Jan 17, 2011 | Honeywell Heating & Cooling
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
