Question about Connex 3300 240-Channels Base CB Radio
DESCRIBE IN DETAIL HOW TALKBACK IS DISCONNECTED ON A CONNEX 3300 PLUS THANKS
Turn the T.B. (Talk Back) switch off.
Posted on Oct 19, 2010
I want my talk back louder on my connex 3300hp
  • Under the top cover of the radio is the solder side and a 440 Kilo Ohm resistor (See Pic)
  • More resistance will quite the talk back. Less resistance will make it louder. You will need to experiment a bit to find the level that suits you. I would start with a 200 Kilo Ohm.
  • This is for the more common Connex with the knob that has an adjustment for echo/talkback. If you have the other on then say so and I will direct you for that one.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Oct 01, 2011 | Connex 3300 240-Channels Base CB Radio
How do i cut out talkback out of my connex 3300
There are many versions of the 3300 , however in most cases (not all) remove the yellow wire from the "echo" switch. Let me know if this helps.
Mar 07, 2011 | Connex 3300 240-Channels Base CB Radio
How can i disconnect the talk back on a connex 3300 plus? pleasa be specific on directions. thanks
in older connex 3300's you cannot disable the talk back. Its part of the audio chain. If you disable the talk back you will loose your audio. There are 2 things you can do.
Hook a relay to the speaker so that when the radio key's id disconnects the speaker. (Big pain, not worth the trouble.)
The other will not disable the talk back but it will stop any squealing.
Use a noise canceling mic. An RK-56 will work great. You will get no squealing with that mic.
Oct 19, 2010 | Connex 3300 240-Channels Base CB Radio
Talkback can i put it on a switch
You can. Just wire a switch in between the resistor, and the solder point.
Sep 29, 2010 | Connex 3300 240-Channels Base CB Radio
Knob functions
they can help you with this 10 meter radio it has a talkback reverb with a rodger beep
www.theradioco.com
techman
May 12, 2010 | Connex 3300 240-Channels Base CB Radio
I have a 3300 connex, something is heating up, you key up and watch power decline, hooked up to an external meter talk back has been modified, radio has had some mork done in the past, all in case
if it has the RELAY talkback. REMOVE IT !!! put back to stock after few months to year or so. it will mess up the radios..
but power prob. check the rf finals, and audio transistors. those two will cause low rf power.
Nov 27, 2009 | Radio Communications
Connex 3300 radio
If their isn't a switch you will have to go into it and disconnect it. I would recommend having a professional do this. It is very miticulous.
May 31, 2009 | Connex 3300 240-Channels Base CB Radio
Disable talkback
one turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
89 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
