Question about Whirlpool Dishwashers
I have whirlpool adp4601 dishwasher 14 mnth old. it will not spray. i get 5 flashes error, i have taken spray arms and cleaned but still problem exists
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
  • 14 Answers
SOURCE: whirlpool GU3200 dishwasher
The illusive technical repair sheet that isn't there...
Turn the thing a little further and pull UP. It'll come out. You've got to put some muscle into it!
The manual for the GU1000/1200/1500 is here (it's almost the same and as close as I can get you to a 3200)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jeremy
Posted on Dec 29, 2007
aborcass
  • 2651 Answers
SOURCE: top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Posted on Feb 26, 2008
SOURCE: dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
Posted on Apr 16, 2008
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
I have a Bosch SHU9955UC/14 dishwasher. I am having problems with the top rack not cleaning. The dishes on the bottom rack are cleaning just fine. I have taken the rotating spray arm off and cleaned it...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jan 07, 2011 | Bosch SHU9955UC Built-in Dishwasher
My DU1145xTPQA whirlpool dishwasher is not cleaning like it used to it is leaving soap on the dishwear. It is about 5 years old and I wonder if some of the passages might be getting clogged by hard water...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 16, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
A guess: the solenoid that directs the water from the pump is not opening fully. Clean it. It is a little nasty to get to but will likely cure the problem.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Top rack not cleaning
Feb 25, 2008 | Dishwashers
Dishwashers Logo
145 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
