Question about KitchenAid KHWS02R Front Load Washer
My washer is not finish the sicle and what I get is code F 06 on the digital panel what I need to do
    President:
  • 1,932 Answers
F06 is Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Thank You
Posted on Oct 13, 2010
Is not taken the softner and the bleach
Clean the dispenser with boiling water and see if it is just a sticking problem, these get gummed up after a while.
Aug 19, 2016 | Bosch Nexxt 300 Series WFMC2201UC
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer dos not drain complitly, in the last sicle, wath doyou tink worn out pump?
no, i do not think it is worn, but there is a possibility that it may have a lot of debri inside of it...
also check to make sure your hose is not kinked
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Sharp Copier AR-5132
Generally F codes have to do with the finisher(used to be called a sorter). with the machine off, diconnect the finisher cord from the copier and power back on. This should allow you to test the copier. I'm not sure on this model how exactly the finisher cord comes out. but it should be self explanitory when you see it.
Oct 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
CLOTHES COME OUT REALY HEVY AND WET AFTER WASH?
It sounds like the spin dryer is not working properly.
Oct 24, 2008 | Washing Machines
Washer wont start
see this link to test it for issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Jan 13, 2008 | Whirlpool GHW9100L Front Load Washer
KitchenAid KHWS02R Front Load Washer Logo
47 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
