Question about Dell Latitude C400 Notebook
I have my laptop installed with Linux OS. i want to replace it with windows XP. i dont have cdrom. can i do it using the USB port? is there a chance that i might encounter a crash? what should i do? please help me
You will have to have the external compatible cd drive for the C400 or find create a server to push the new os on. email me at fb_patterson@yahoo.com and I may be able to help you further.Please note, not all the cd drives that say they are compatible are compatible so be careful before you buy one.
Posted on Oct 17, 2010
I am cannot install OS Xp on laptop blue Il1,because drivers not support
Actually the problem is that the sata raid drivers of the IL1 is not readily available on the windows XP installer package. Another problem is that you cannot use the drivers on the installation because it uses a disk drive for loading and the IL1 have no disk drive or CDROM with it.
The solution is download or get the sata raid driver for the IL1 placed it on a diskette and attached an external CDROM and an external disk drive on your IL1. Open your notebook place the Windows XP CD in the CDROM, place the sata raid driver diskette on the disk drive. Make sure that the booting priority is set to the usb CDROM.
Upon loading of the Windows XP installation, you will notice a message on the status bar below the screen asking you to press F6 if you want to add additional device, press F6 and follow the instruction on adding the sata raid driver. Then your installation will continue till it finishes the Windows XP installation.
There is another way, but a little complicated. It is making a flashdrive installer of Windows XP OS. an integrating the sata raid driver in the flashdrive Windows XP OS installer. there's a guide somewhere in the internet that discuss the process step by step, I just can't remember on what site. I fount it by searching the net, I'm sure you can find it if you have time.
For now that's all I can share. Good luck friend.
Dec 14, 2010 | CTL IL1 Notebook
I can not understand the tipe of my usb and that's why i dont know where i can find drivers from
If you are using OS like Windows XP SP2, Vista, or Win 7, the USB 2.0 ports are not a problem.
You need to install USB drivers if you are using Win9X series OS.
If you are using Open Source Operating System like Linux, DOS, etc...., you have to install the USB drivers from Motherboard manufacturers Sites or your USB hardware manufacturers Sites.
Jul 23, 2010 | Computers & Internet
Is it possible to install 2nd 0/s on separate hard drive 40gb,id not sata attached via usb with laptop of dell inspiron 1525 c2d give steps to install
It depends what kind of SO do you want to install
I recommend you to user an USB Linux distro.
Anyway, normally when installing any SO lets you select the partition where you want to install the SO.
Select the partition belonging to the USB External HD, and do everything else normally.
You must have in mind that you will lose everything in the USB HD, and that using it this way the OS will work only when the HD is plugged to the same PC, it may work with a different PC with different hardware but the SO will install the new drivers for the new hardware.
That's why I recommend you to use linux, check this out www.pendrivelinux.com/
Mar 19, 2009 | Microsoft Windows 98 for PC
How to work with an acer aspire mini laptop with linux?
2 - it does not have a cd ! This is not a linux or windows thing ! U can use a usb cdrom if u realy want to...
3 - u;ll need a usb stick bootable with dos OS on it and the kit for xp ... there is plenty of info on google... But i recomand useing the linux(faster, more stable ... prettyer :) )!
Jan 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Install window on a portable ide harddisk
i dont think so dat window could b installed on usb.
Dec 31, 2008 | Computers & Internet
Installing windows xp
you can follow these steps
http://www.eeeguides.com/2007/11/installing-windows-xp-from-usb-thumb.html
I was able to do this for an acer aspire one, also a notebook with no cdrom drive
Oct 13, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
"USB Device Not Recognized" - any usb device
Hardware to old or a spontaneous defect ? Burn a free linux live dvd ( mint or other live distro) to recognize a good working device.
Boot on cdrom and see what happens.
DistroWatch com Put the fun back into computing Use Linux BSD
Mar 08, 2017 | Electronics - Others
I cant install Linux on my Laptop
more info, please: anyone trying to help you with this needs to know the following: what linux and what linux boot method (USB, CD/DVD) and how you made your linux boot disk, at what point the Linux installer stops responding, and please God did you shut down Windows before starting the Linux installer?
Jul 29, 2008 | Computers & Internet
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Dell Latitude C400 Notebook Logo
Alun Cox
