Question about Garden
I need a parts diagram for a stihl 028 av chainsaw. Thank you.
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
dontbother10
  • 2220 Answers
SOURCE: i need a fuel hose diagram for a stihl model 028
Stihl IPLs (exploded parts list) are propriatary, You can request one here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
http://www.stihlusa.com/contact.php
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Dec 24, 2009
lindsay836
  • 677 Answers
SOURCE: stihl chainsaw 028 wb will not start it has spark,
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Posted on Feb 05, 2010
dontbother10
  • 2220 Answers
SOURCE: Stihl 028 Gas Tank off?
Any other manufacturer I would provide a link to an IPL. Stihl considers them proprietary.
Go here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A bunch of folk that enjoy all chainsaw. Please try search, find an applicable thread and join the conversation.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Search for your saw and send a PM to an active member that replied to a similar request works best.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 18, 2010
  • 4088 Answers
SOURCE: I have a Stihl 028
Just remove the spark plug, connect the wire, and lay the plug base on engine metal. Turn on the ignition and pull the starter. If nothing, first try a fresh plug gapped at 0.020". If still nothing, service on the ignition system is required. Suggest finding a Stihl service dealer if you don't have mechanical service skills. Hope this helps!
Posted on Nov 23, 2010
Need a Stihl 028 chain saw parts digram
not saying its on there but type diagram you want into google click images its worth a look as theres images for mostly everything.
Dec 21, 2016 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Is there supposed to be a cyntrifical clutch on a stihl 028 av super electronic quickstop?
Yes; see page 37 in your OM. You read it before using your saw right?
http://www.stihlusa.com/stihl_ownersmanuals/STIHL028_with_safety_manual.pdf
Lou
Mar 21, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Go here:
Lou
Mar 17, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Whatb is the gap for points on an 028wb saw
Stihl 028 OM can be downloaded here:
Stihl Product Instruction Manuals
If equipped with points 0.015" ± 0.001".
Lou
Mar 03, 2010 | RTO Spur Sprocket For Stihl 017, 021...
NEED NEW CHAIN DRIVE UNIT INCLUDING PLASTIC
The model 028 Stihl Chainsaw was in production for many years and the clutch drum sprocket (or chain drive) came in three (3) versions over the years of production.
For several reasons, it is best to take the saw to an authorized Stihl Dealership (Locate your nearest dealership HERE) for production identification, evaluation of cost-effectivness and availability of parts.
Reason 1) The first-generation 028 saw is approaching 30 years old.
Reason 2) Extreme heat caused by a locked chain-brake can damage the engine case and render the saw unfixable (part support is going away due to age).
Reason 3) The shear cost of parts and amount of time it would take for a DIY repair.
Reason 4) The plastic gears you mentioned are the drive system that make the chain's oil pump work. If the plastic is melted, the oil pump is likely to be damaged as well. In most cases the oil pump cover gets damaged ... the list goes on and on.
Genuine Stihl parts are not sold online and aftermarket parts would be a gamble. It's up to you to decide if the cost, time and effort are worth it.
Hope this helps.
Oct 04, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
1,047 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
