Question about Ricoh GR-1 35mm Point and Shoot Camera
Any one know where i can get my Ricoh GR1 repaired?! shutter seems to have stopped firing.
I have an old Richo 35mm SLR purchased in 1968. When you advance the film and release the winding lever it fires the shutter. Can i do a DIY repair.
Doubtful. The inside workings of older film SLRs are like watches, lots of gears and such. If something has broken, which this sounds like, then you'll need replacement parts and a source for them. You might try checking this website for more info:
Ricoh SRL Systems manuals instruction
Dec 16, 2014 | Photography
Can the 35mm SLR Ricoh Kr-5 Super II camera still work with the batteries dead?
Straightforward answer: no. Everything needs power to work except for the self timer, but even that won't fire the shutter without battery power.
Sep 12, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Light meter stopped working and shutter stopped firing
about the only thing you can do other than take or send your camera to a repair shop is to remove the batteries and clean the cap and contacts with a pencil eraser be careful not to damage the contact. also move the on/off switch and select knob back and forth a few times to clean the contacts. i would get a repair estimate first as there are no new parts available for this camera.
Jun 02, 2009 | Photography
580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Apr 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Feb 21, 2009 | Ricoh XR-10M 35mm SLR Camera
Sears ks-2/ricoh xr-7 film advance and shutter release problem
You probably need to take the camera in for repair. It sounds like the film transport is not connected to the shutter/mirror cage ***'y.
Jan 26, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Sears ks super camera.
You'll have to remove the bottom cover. Either the mirror box or the shutter are stuck. re-cocking it is possible by moving the wind stop clear of the bottom portion of the film advance shaft.
Aug 20, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Jul 08, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Ricoh GR-1 35mm Point and Shoot Camera Logo
64 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
