Question about Whirlpool Dryers
The whirlpool dryer I have is loosing its sealant strip on the inside of the back of the dryer. Does it need to be replaced and if yes how.
  • gretcheneric Jun 01, 2008
    I would like to know if we can fix it ourselves, and if yes how?
    The model number is LE9500xtw1
    Genius:
  • 3,587 Answers
Well...it's not simple..will take around 2 to 3 hours...
first thing..can you provide the model number, and lets see if we can find you a service manual
Posted on Jun 01, 2008
  • Patrick Michaels
    Patrick Michaels Jun 01, 2008
    are we referring to the same item here? Ginko?
  • Patrick Michaels
    high fives ginko..hopes he's right on this one.
  • Whirlpool Master
  • 19,396 Answers
It should not be a difficult operation, contact a seller here and order a replacement for your model. You will be asked for model number.
  • Ginko
    Ginko Jun 01, 2008
    The strip is self adhesive, just remove the old one and replace, here is one more part distributor
  • Ginko
    Ginko Jun 01, 2008
    the part is called seal or seal strip.
  • 796 Answers
Yes..it may lead to some kind of water or heat leakage..
you could call for a technician o that company..
they ll do it for you
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
The wedges inside dryer, can they be removed and put back? I hear lots of change and things inside of them.
The baffles yes take off the top loosen the screws don't take them all way out rotate and shake loose baffle repeat for others
Sep 22, 2014 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I have a whirlpool RM278BXS microwave oven. Inside the microwave oven along the rear bottom is a thin strip of sealant. The sealant is melted/burned in the middle section for about 1-inch long. I can...
Your best bet is to pull out all the old seal you can, and to trim what's firm with a razor blade.
Sand it smooth if necessary, then clean it squeaky and apply new caulk / silicone sealant.
Leave the door open to allow it to dry out overnight.
If it's not repaired, moisture can cause rust, which will lead eventually disintegrate the metal and lead to to arcing and possible fire in time.
Jun 07, 2012 | Whirlpool Microwave Ovens
Model fde336resi loose drum
There are 2 areas to check for this dryer drum. The back center bearing looks like a small trailer hitch ball which is attached to the drum. It fits into a plastic socket on the back wall of the dryer. To remove the drum, you need to take the dryer front off and disconnect the belt that goes around the drum. Then use the belt as a handle and yank up the back of the drum to lift the ball of the drum out of the socket. The plastic socket is what usually wears but you can get a complete kit including the ball and socket for about $20. While the drum is out, look at the inside edge of the drum opening. Should be a white plastic bearing strip completely around the opening.If cracked or missing replace those also. Should be 2 strips. Thats all that supports the drum in the front.
Mar 24, 2012 | Frigidaire Electric Dryer
I have a whirlpool inglis dryer that is about 5 years older and I have a 3 prong electrical cord, in the back of the dry were the electrical cable connects into the dryer (There is 3 connection locations)...
Hi johnebrenner...
Most likely cause of the wire being burned is a loose and arching connection.
I would recommend that you replace your existing cord and wire with new ones and make sure to tighten your connections very tight, but do not strip the screws by over tighting..
Please take time to rate me
Aug 23, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer works but has no heat. Voltage is good. Could it be the TCO?
I suspect that your heater strips in the dryer have burned out. Just to give you an idea, I have replaced my heater strips in my 40+ year Whirlpool dryer two additional times over the years. You will have to take the back off of the dryer after disconnection the 220V plug and examine the heater strips.
Nov 30, 2010 | Roper Dryers
Dryer - high current has caused the red wire in the 220
The problem is usually caused by a bad connection, or loose wire.
Strip back wire, and remake connection, if the terminal is burnt, it may be neccessery to replace the connector or box.
Please rate my solution.
Thanks.
Nov 21, 2009 | Whirlpool Dryers
One of the vanes inside my gas dryer is loose and makes a loud banging sound when the dryer runs. How can I tighten it?
depending on style dryer,you need to access drum.usually top will pop up and hinge back.rotate the drum by hand counter clockwise till your loose vane is on top,you should see screws or maybe a missing one .add flat washers to secure better.If the plastic threads are broken/stripped replace vane. Hope this helps ,Please rate my solution. :)
Jun 25, 2009 | Dryers
Flipper inside Dryer is loose
unplug dryer open back find the screws on the out side of drum and tighten them
Feb 02, 2009 | Whirlpool GGQ8831L Gas Dryer
We have a Whirlpool dryer. The strip of sealant is peeling off the inside back of the dryer. Does it need to be replaced, and if yes, how.
yes or else you may rust stains or torn clothing ..remove dryer front and pull tub out cut seal off and install new seal may a task not for the weak of heart can be a dog for unexperienced
Jun 01, 2008 | Whirlpool Dryers
Open Questions:
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
