Question about Roper RGX4634KQ Gas Dryer
Dryer starts and runs, but heat turns off after just a few minutes. Does not come back on.
  • Roper Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101..
Posted on Oct 15, 2010
Kenmore dryer runs only for a few minutes
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
DRYER RUNS SOMETIMES MID CYCLE DRUM QUITS TURNING BUT STILL HEATS UP COMES BACK ON AFTER A FEW MINUTES
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 26, 2011 | GE Dryers
The dryer is started and the flame starts to dry the clothes. The dryer runs for about 10 minutes then the flame goes out. The dryer continues to run but the flame is out and does not turn back on. ...
Remove the entire venting system and thoroughly clean the lint out. This does cause this problem you have for no heat after running for a few minutes
Sep 01, 2010 | Estate EGD4300VQ Gas Dryer
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Dryer won't heat and shuts off
Go get you a new thermostat or have the appliance guy fix it under warranty.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Dryer gets hot for the first few minutes only
first check your venting. if you have backed up lint then it will not heat as well. if it's not your venting i would check to see if your heating element is broken and shorted to the casing..some times it will still heat if the coils weld themselves to the casing...if the heating element looks good then i would turn to your electrical.
Jun 16, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heats up cools down in few minutes? Kenmore gas
we need to take a look at the heating system and exhaust,,where going to start with simplest ok..your filter is cleann...check exhaust from back of dryer leadind all way out house make sure that path is clear...next pull exaust off and run dryer,,if not good,,let me know ,,onthejob
Jan 10, 2009 | Dryers
Roper RGX4634KQ Gas Dryer Logo
59 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
