Question about Kodak ESP 5 Printer
Hi a member of my family has a Kodak esp7 all in one printer. it suddenly refused to print. the status monitor displayed a red x I got it working again. further investigation showed the printer had been disconnected. I just would like to know does the red x mean the printer is disconnected or disabled? Thanks for clarification on this.
  • redbionic Oct 13, 2010
    Thanks for your answer. we tried switching printer and laptop off and on again but it didn't clear the red x there were no paper jams. I was wondering does the kodak esp 7 receive updates were it needs the usb lead connected? This printer normally is a wireless connection. other than that i can only think the kodak software crashed. i updated the kodak software from their site to fix the issue. Also cleaned the printheads. Thankyou.
    Yes very helpful. would recommend to others.
  • Kodak Master
  • 13,433 Answers
that seems to just be a general error. it is probably disconnected, out of paper, paper jammed, etc. You should get a more detailed error message.
if you just get a red x just press OK / enter, or reconnect it or turn it off and on again.
Posted on Oct 13, 2010
  • Ekse Oct 13, 2010
    well again you should get a error message if there is a problem with spesifics pointing you to the right direction.
    Running the setup or updating the software reconnects the printer and it should work normally if its just disconnected for some strange reason.
Ho do i know which ink cartridge is low
Hi
the easiest way is to send a print job to printer. If any cartridge is empty, the printer should refuse to print and display an error message. This should indicate which cartridge is empty/not recognised - with a red X above the empty colour. Another way is to go to 'printer properties' then 'maintenance' page and click on 'Status monitor' button.
Hope this helps & good luck with it.
Oct 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
When prints come out the landscape is all white .sky and sea ok. photos comes out with lines on them
Verify that the ink cartridges are not damaged and are completely seated in the printhead:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
    For more information view Installing the Printhead and Ink Cartridges:
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
    NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem.
Dec 05, 2010 | Kodak ESP7 PP All-In-One Printer
How do i get a printhead for esp7 all-in-one
http://selfservice.kodak.com/service/panels/solution/printSolution.jsp?solutionId=1771&t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&viewMode=NORMAL&windowType=SAME&highlightInfo=&isRecord=false
The above link goes to how to install a printhead for an esp7 all in one printer.
http://www.kodak.com/global/mul/consumer/print/en_us/fairly_priced_ink.html?CID=go&idhbx=ink
The above link takes you to a page that allows you to compare prices on several ink sources from Kodak.com which are recommended for your printer.
Please don't use aftermarket ink in your printer as it is not recommended for optimal performance.
Aug 17, 2010 | Kodak Office Equipment & Supplies
Draft printer setting not printing correctly
its bringing with error code 3825 when i try to print some thing from my computer
Jul 01, 2010 | Kodak ESP7 PP All-In-One Printer
Kodak ESP7 - Stops printing after first request.
Go on kodak web site and down load updated drivers for this thing.  Close non-essential running applications in the background if you got an old slow processor chip in your computer.
Oct 26, 2009 | Office Equipment & Supplies
Kodak esp7 wont print black
Click on menu on the printer,scroll down and choose clean printhead or go to maintenance and then click on clean printhead .After that try to print. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad
Sep 28, 2009 | Kodak ESP 5 Printer
No Kodak printer detected
call kodak @ 1800 421 6699. they will fix ur problem. if nbot,they will replace ur printer or may be software issue with ur printer they will assist u better as this issue cannot be solved orally or by chat
Jul 19, 2009 | Kodak ESP 5 Printer
ESP7 will not print my yellows.
call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. Replacing the Printhead will solve the issue.
Jun 18, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
188 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
