Question about ViewSonic Computers & Internet
I have a new viewsonic va223wm and the whole screen went side ways how do i fix it
2 Suggested Answers
AndystUK
  • 131 Answers
SOURCE: ViewSonic P815 scren suddenly went black
either the bulb/tube has deteriorated. or long shot but happened to our old telly and that was, the power cable solder joints had worn loose.
If you feel capable of yeilding a solder gun then read on.
ANY LOOKING OR OPENING UP OF TV CASES MAY VOID ANY WARRANTIES. YOU MUST UNPLUG ANY POWER LEADS AND AVOID TOUCHING THE TUBE END INSIDE THE UNIT AT ALL COSTS. speech over we shall continue...
remove back of telly and carefully arrange screws in a circle shape to mimic their removal locations. trace the power lead cable physically by following the lead to the motherboard. to the man in the street thats the platform where all the components sit. the cable will be soldered to this board. visually check to see if there is a sound solid solder joint, marrying the two as one. if these are loose then you might be in luck.
resolder joints, cleaning off any residue of flux. replace back cover and power up.
Hope this helps
AndystUK
Posted on Oct 24, 2009
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
Half way through pc posting screen goes blank Viewsonic VA1912W LCD Monitor
Common failures in this monitor is the 470uF caps in the inverter section (close to the inverter transformers), but you should replace all the caps in the 5vdc and the 12vdc as a whole set. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
Hi! How do I replace a Viewsonic V1250 tablet pc screen. Mine went completely black with no picture.
If the screen does not have a cracked glass, then it maybe a back-light problem, maybe a faulty inverter or a faulty CCFL lamp. These components are much cheaper to replace than the whole LCD screen.
For service, parts and DIY info check out LCD Parts WEB site - click on this link to their WEB site :-
www.lcdparts.net
Dec 30, 2009 | ViewSonic : V1250 Convertible Tablet PC...
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
Web page will not cover the whole screen on ViewSonic monitor
Take it to a monitor repair person. The horizontal size circuit is being held down by parts which have aged. Parts can be replaced.
Mar 24, 2009 | Computers & Internet
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
Monitor turns on and off
Is it an HP or a Viewsonic screen ?
Either way, looks like a power supply problem to me, some Viewsonic screens are known to have a problem with their inner power supply card, If your screen is still under warranty I suggest you don't lose time analysing the problem and just make them come and fix/replace it
Nov 06, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
VIEWSONIC GT775 PROBLEM
Hi no sorry their is nothing you can do it would cost to much to replace the screen you are better of replacing with a new one not alot of places do this sort of repair as it costs more than a new one this problem is not an eays fix it just costs to much to replace the lcd screen let me know if you need further assistance ok
Mar 08, 2008 | ViewSonic VX924 19" LCD Monitor
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Computers & Internet Logo
57 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
