Question about Dryers
The Dryer works, but it will not dry anything. The air isn't hot. There are no kinks in the duct line, and the air is blowing all the way to the outside.
  • 1,531 Answers
You need to first check the main power at the terminal block and make sure there is enough power there.With out 220 volts the unit can run but will not heat.
then you need to check all the thermal fuses and heating element for continuity,if you find one part that does not hacve any continuity then replace it and your proplem is solved.
the element and fuses are usually located behind the back panel below the main terminal block.;
some unit have them located in the cabinet below the drum and the front panel needs to be removed in order to gain access to them
Posted on Oct 13, 2010
Partial heat
when was the last time you cleaned out the dryer and vent line?all a dryer does is move air,if the dryer hasn't been cleaned it won't dry the clothes.your model has the lint filter on top,unplug the dryer,pull it out away from the wall,disconnect the vent line from the back,now pull it out so you can work on the back,first pull out the lint filter and remove the 2 phillips screws in front of it on the top panel,now go in the back and remove the back wall,on the left side you'll see the metal duct that the lint filter slides down into,remove the 4 screws and you already removed the other 2 screws on top so now you can remove the metal duct and clean it out,vac up ant lint in the back,if you have a shop vac set it up to blow and blow out the blower wheel and the heater duct on the right side,after it's all cleaned up put it back together but don't put the 2 top screws in,after you have it back together clean out the vent line,if it's a long run i use a leaf blower,stick the leaf blower into the vent line and blow it out to the outside,just make sure the outside duct is clear,no cage or anything that will block the lint,put the vent line back on and push the dryer back,now pop the top and clean out the front of dryer,i'll send you a viideo on how to take the dryer apart.
http://www.youtube.com/watch?v=xGIG8Wo5-N4
good luck and if you know the heat is working most likely you have a block somewhere and you should do this once a year so your clothes will dry on time,if you see that it takes more time to dry your clothes this is where to start also so you don't have a dryer fire.
Nov 12, 2013 | Whirlpool LER4634J Electric Dryer
Thermal cut-off
when the thermal fuse or the high limit pops it's because the dryer is running to hot,all a dryer does is move air,when one of the fuses pops it's from a block from lint either in the lint filter duct or the vent line,if the air can't blow outside or out of the dryer the fuse will blow.if your vent line is long remove it from the back of dryer and stick a leaf blower into the vent line and blow all the lint outside,make sure there isn't a cage or anything blocking the outside hood,then pull out the lint filter,take the dryer apart,remove the lint filter duct and clean it out,also vac and blow out the cabinet and motor,you should do this once a year,your clothes will dry on time,less parts will get damaged from overheating ,your electric bill will be less and most important you won't have a dryer fire.hope this helps,the fuse will keep blowing until you clean out the dryer and vent line.
May 16, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
My LG Tromm dryer is not drying. it turns & gets hot but the dampness is not blowing out of the dryer, it just makes them hot & wet
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Mar 20, 2011 | LG DLE2514 Electric Dryer
Dryer takes longer to dry, doesn't get as hot as before
Feb 10, 2011 | Dryers
LG DLE5977W Clothes Dryer takes forever to dry average loads of clothes. Authorized sevice tech recently cleaned air ducts and machine, but drying times per load takes hours. Any fixes to improve drying...
the most common problem is air flow restriction.make sure the machine is not pushed back to far and the ducting is getting kinked or blocked some how.when the machine is running go to the outside of your home and feel for the air blowing out of the dryer it should be pretty strong if it is not then there is a restrtion in the main line somewhere.and a leaf blower can be used on the inside of the house by sticking the tube in the vent hole and blowing it out but make sure that the outside part of the venting is clear so anything in the main line can come out.
Nov 17, 2010 | LG DLE5977 Electric Dryer
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
Takes to long to dry clothes
Check your lint trap and piping. Make sure that no lint is clogged in the lint trap all the way to out side. This is a pretty common issue.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Feb 10, 2009 | Frigidaire GLER642A Electric Dryer
Takes a long time to dry one load
Try running dryer with venting disconnected to eliminate that as the problem. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
