How do you display a s-vhs input on a techwood tv?
  • 998 Answers
Ti has a problem in the power supply try to find a swollen capacitor and replace it
Posted on Oct 13, 2010
  • Noel Jucutan
    Noel Jucutan Oct 13, 2010
    sorry wrong send
How to connect Magnavox TV Model CH 3930 AL O2 to VHS player?
Actually, what you want to do is connect the VHS player to your TV. Your VHS player has three output leads: R. audio (red), L. audio (white), and video (yellow). These connect to corresponding inputs on the rear of your TV. Select VCR as the input source to your TV.
Mar 27, 2017 | Magnavox Televison & Video
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
Techwood 42in tv model 42832 hd digtal it turned itself of,cant get no picture,but blue stand by switch still turns on and off
It sounds like your TV's display has been routed to a different INPUT than the Cable/TV input jack, like a VCR in put or an RCA input. You need to change the input back to TV from VCR or LINE1 or RCA, so on. How to do this without the original remote, you are going to have to look up the program code for the universal remote and program that remote correctly, once done, change the TV Input until you're back on cable.
Mar 29, 2011 | Televison & Video
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
I would like to know how to conect a Sony VHS to a TV? What leads go where etc. Thank you for your help.
hi,
you can connect the audio video out of your VHS to the audio video input of your tv. for that you need an audio video cable (have three RCA pin at the both side, one for video(yellow) and the other two (red and white) for audio.
connect the one end of the three rca cable to the VHS's audio video out according to the color code. and the other end to the tv's audio video input.
Then select the corresponding AV input in your tv using the remote.
ok
Jan 25, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Cant access input jacks
Go into the setup menus IE:Video,Audio etc: The last page has the video label option. It is there where you select the label you want to give such as VHS,Beta,DVD etc. You can also select SKIP and that is why you can't access those inputs. Select any label besides SKIP and your issue will be gone.
Apr 23, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
Top Televison & Video Experts
