Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
How do you replace grey seal between door & drum?Has a small hole.Found the part online for $64.00
  • 5,911 Answers
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Posted on Jun 03, 2008
I rotated the damaged part of the seal to the top on my Whirlpool duet,and things worked out fine - no more leak !!! JB
Posted on Apr 02, 2012
Whirlpool duet ghw9100lw lights on, not locked and still won't start
Just above where the washer door strike goes into the latch is a small round piece of plastic that activates a switch in the latch- is that still there? It will push in and come out as it is spring-loaded.
Oct 22, 2012 | Whirlpool Washing Machines
Duet ghw9100lw washing machine drum has scratched a hole in my tub which causes it to leak, after it being patched i did another load and again, it leaked then i smelled an odor like burnt rubber....HELP!!...
You need to find thge cause of the hole and fix that. Then hyou can either platsic weeld the tub or find some other means of pluging uop the hole for good.
Apr 04, 2011 | Whirlpool Washing Machines
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The gasket has cracked on the bottom and leaks. I have bought the new door/drum gasket. Where can I find instructions as to how to replace this large gasket/ring that stops water from leaking out the door
This is not to my credit, but I found it on Fix-it--
here is an online manual ,as txt url wraps around you may have to copy paste it .
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose"
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
hiya
firstly you will need to unplug the machine, then remove the lid, open the door and remove the metal retaining band from around the lip of the door seal (may need a small flat screwdriver to lift it up).
once the retainer is off the door seal should pull away from the front lip, this can then be folded inside the machine and out of the way for the next bit.
next you will need to locate the doorseal retainer on the inside of the machine may need a 7mm socket and small ratchet or a small philips screwdriver for this one, this one only needs to be loosened enough so that the doorseal will pull away from the drum.
refitting is pretty much the reverse of removal.
you MUST make sure the seal is on the drum lip corrrectly before refitting the retaining band or it will leak.
you MUST also make sure the drain holes are lined up with the ones on the drum.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,416 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
