Question about GE GSH22JFR Side by Side Refrigerator
I have a GE R/F TFH22PR that did not come with a water filter how can I attach and what kind do I use
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: GE Profile Side by side model number TFH22PR.
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
Testimonial: "If water is getting to the door wouldn't the water flow have to be good? Seems like testing the water flow would be a waste of time"
Water is not dispensing and filter is only a couple of months old and replace filter light is not on
You may have a failed water dispenser solenoid coil. Also, the water valve attached to your home's water line may be blocked by debris or mineral deposits.
Oct 02, 2014 | GE Refrigerators
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
I replaced defrost heaters and defrost contoller on GE TFH22PR and the heaters still don't work. One of the old heaters actually shorted out - is it likely the oveload needs to be replaced too? is there...
There are only 3 parts to the defrost " system " . The defrost timer , defrost bimetal ( the 1 inch cylinder piece clipped to the top of the coils , with 2 wires going to it ) and the heaters .I do not know what you are refering to , as the " controller " . You have replace 2 out of 3 , so replace the third , which is probably the problem .
Sep 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by side model number TFH22PR. Works great, but ice maker not working. It produces water from door just fine, but no ice. What's up with that? Clogged somewhere?
Hi
Thanks
Rylee
Jun 03, 2010 | GE Refrigerators
Installed a complete Vitasalus water fitraion system. From our pond to our home. The water is still very dirty. Don't know what else to do. Help?
put more filters in the line from diferend kind water filterd tru 3 or 4 filters are more clean you have to now whath are the thinks making the water dirty like yron or ????
Nov 08, 2009 | General Electric GE SmartWater Household...
Moldy taste from water/ice for GE profile
What kind of external filter did you use ? If you used an $11.00 cut the line and attach on each end of the tube filter , this will not work . Go to home depot and invest in the $50.00 filter which mounts to the wall , where you replace the inner certridge by untwisting with your hand . This filter has replaceable charcoal , calcium , lime ,etc cartridges . You may have to try different cartridges to find the one your happy with .
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
