Question about Business Objects BusinessObjects Enterprise (KNOWLEDGE)
Hello!Experts, when i try to open infoview by this method : Start->All Programs -> BOE3.1 -> .net infoview, I get the following error : This page contains the following errors: error on line 1 at column 2: StartTag: invalid element name Below is a rendering of the page up to the first error. I used another way by opening infoview from browser by typing the following url :http://servername:portno/InfoViewApp/logon.aspx, I get error no 404 ie. "Page not found". My IIS is working just fine. I am deploying by using IIS as I am using the sql server as my database and its for .net website. Many thanks....
3 Suggested Answers
  • 12 Answers
SOURCE: When trying to refresh a Business Objects error... DMA0007
If changes have been made to the universe it may well be that in Deski you're using a local copy of it,
I would first advise exporting the universe to the repository (cms ) and having another go in Infoview just to ensure that the same copy of the universe is being used.
If it still fails, you will need access to the Business Objects server as it could well be that the connection on the server is either missing, incorrect or using a different version of middleware.
The fastest way to check on the server, is to launch Deski directly on the server and import the report > refresh it and see if you get the error.
If so then we know that it's a connectivity issue.
Posted on Mar 14, 2009
  • 3247 Answers
SOURCE: Hi all i am not able to open my admin console.
I believe BO console uses Java runtime environment. Not sure which version of Java is compatible with the version of BO that you have.
If you can find out then compare with the version of Java RE on your machines. You may have to revert Java to the appropriate version. The version you need should be available from the website.
Posted on Oct 29, 2009
Microsoft Outlook 2013
In most cases it is the corrupted Navigation Pane settings file that prevents Outlook from starting successfully, so the first thing you need to do is to mend it. Here's how you can do this on different operating systems:
1. If you use Vista, Windows 7 or Windows 8, click the Start button. On Windows XP, click Start > Run.
2. Type the following command in the search field:
outlook.exe /resetnavpane
Note: Be sure to enter a space between outlook.exe and /resetnavpane.
3. Press Enter or click on the file in order to reset the Navigation Pane settings and then open Outlook.
Or try to repair your outlook.pst file using Outlook Fix Toolbox
Findit here https://www.fixtoolbox.com/outlookfix.html
Oct 23, 2015 | Microsoft Outlook
How to fix error 2503 in acer laptop
What are you trying to install?
┬ĚDid you get any error message along with the error code?
┬ĚDid you make any changes on your computer prior to this issue?
Let's try these steps and check if it helps.
Method 1
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Method 2
Check permissions within the Installer folder. To do this, follow these steps.
1.Click on Start and in the Start Search bar > type in > c: /windows/installer.
2.Right click on c: /windows/installer at the top under programs and click properties.
3.Click on the security tab > Verify if System and Administrator account has Full access permissions.
4.The Everyone account should have read and execute permissions, List Folder Contents, and Read.
Jun 11, 2014 | Dell Studio 15 Laptop
I am getting error code 0x80070005, how do i fix this
Windows Activation Error : Error Code 0x80070005 I have upgraded my x64 Vista to x64 Windows7. After adding to companies domain, it asked to activate windows again. but its giving the following error when i try to activate it : "Windows Activation Error : Error Code 0x80070005"
The link for the fix is described at the Microsoft Website, link listed below.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-activation-error-error-code-0x80070005/90fb852d-a507-4c76-a672-0be2ecbdb320
Sep 30, 2013 | Toshiba Computers & Internet
When I goto print something, it just does nothing. When I check the print queue, the document is there and restarting does nothing. When I goto the printers and devises it shows the printer as...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | Office Equipment & Supplies
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Hi expert m brother deleted the adminstrator yser
Recover all your files using a Linux Live-CD like http://pclinuxos.com/ - boot from it and copy the files to an external memory/harddisk.
Then just reinstall, nothing else can be done if the admin account has been corrupted/deleted.
Jun 30, 2010 | Computers & Internet
ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
Mar 15, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
The Active Property must be TRUE before the Speed method can be called- HELP ME
The solution tha worked for me (for XP) was to open the "Sounds and Audio Devices" control panel, go to the audio tab, and uncheck the box next to "Use only default devices."
Nov 03, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
180 people viewed this question
Top Business Objects Computers & Internet Experts
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
