Question about Punch Professional Home Design Platinum Suite (26635)
Applying colors Everytime I try to apply a color to a wall my program does not respond? How do I fix this? Thanks
  • Anonymous Jul 11, 2008
    i have the same problem, when I try to paint the wall and the objects,just paint the sky behind the building
Drag paint to very top corner of wall!
Posted on Jul 03, 2008
Dsaf
Posted on Jun 17, 2008
Is there a way to prevent staining my skin when I color my hair at home?
Try putting petroleum jelly around your hair line before you start applying the color. It will act as a barrier and stop the color from staining your skin. Also make sure that you keep your eye on the clock and wash the color out as soon as you are supposed to.
Mar 04, 2013 | Health & Beauty
Tip
Top 3 Tips for Makeup Application
Women scour a beauty forum and online reviews to find the best makeup products; however, finding the right product is only half the battle. You'll also need the right tools and application methods to achieve the most flawless look. Read on to learn beauty advice for applying makeup. <br /><br />Creating a full lip. Apply primer to the lips, which allows the pigment to stick better and last longer. Then, apply a lipstick that is moisturizing to create a plumping effect. Finish off by applying a clear gloss over the lipstick to achieve fuller-looking lips. <br /><br />Highlighting your eyes. Play up your eyes by choosing colors that complement your eye color. If you have green eyes, choose lavender and purple eye shadows. Highlight blue eyes with shimmery browns and deep blue. Those with brown eyes should choose emerald greens. Use the lightest eye shadow color on the lids and the darker color for the eyelid crease. <br /><br />Achieving flawless skin. First, apply a moisturizer with SPF to the skin to smooth out any dry areas. Then, use a foundation brush to apply a primer all over your face. Finish off with a light coverage foundation and dust with powder to set the look.<br /><br />
on Nov 22, 2010 | Health & Beauty
Tip
Step-by-Step Eye Makeup Guide
Even if you've been applying eye makeup for years, it helps to have fresh new tips. Read on to learn how to achieve a more seamless look when applying eye makeup. <br /><br />The first step in applying eye makeup is to use a primer. A simple foundation primer will work around the eye area and provides a more flawless look. Then, apply your concealer to the eye area and use a foundation brush to apply foundation to the entire face and eye area. This will create a nice base for applying eye makeup. <br /><br />Once you've created a base, it's time to choose eyeshadow. Choose a product that rates high in beauty product reviews, such as L'Oreal Paris HiP Concentrated Shadow Duo. The lighter color in the palette should be applied all over the eyelid. Then, use an eyeshadow crease brush to sweep the darkest color in your creases. Apply a liner to the top lid only and sweep on 1 to 2 coats of mascara to finish off the look.<br /><br />
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
My lips have discolored due to constant picking and they look very ugly. can the color be restored
I would recommend using Burts Bee's chapstick. It's one of the only chapsticks that does not have an ingredient that will INCREASE chapped lips. Upon applying, it's not the most moist of the lip balms, but you will notice a difference over a couple of days. Try the different kinds, and find which one is for you. As for the discoloration, for a quick fix, you can use a lipstain (close to your natural color). I like using NYC's lipstain because it's cheaper, AND stays on just as long. Another tip, try applying a good amount of chapstick and take a dry toothbrush and rub the excess skin/dryness away that way. It will enhance your lip color and scrub away the dry mess. Afterwards, reapply the chapstick.
Hope this helps!
Jun 08, 2011 | Blistex Medicated Lip Balm 0.15 oz Stick
Hello, I recently bought some Mac eye/lip liner pencils, and am having trouble getting the color on my eyes.
Try applying your foundation before you apply your eye color. The powder will help the color set and make it last longer as well.
Mar 30, 2011 | M+ Mac Eye / Lip Liner Pencil Black Aloe...
I'm using Goldwell 12BG which says 2+1 on the box. Is the formula 2 oz. of developer/peroxide to1 oz. of toner or is it 2 oz. of toner to 1 oz. of developer/peroxide and should I use 20% or 30%...
Ratio is always developer to color, so a 2:1 is 2 parts developer to 1 part color. Example mixture is 40 ml developer to 20 ml color.
30 vol gives you better control and less damage to your hair. If you have VERY dark hair (level 5/4 or below), you need to pre-lift and then apply the color. It sounds like you're not a trained stylist, so I don't recommend 40 vol as it lifts too fast for most people to get an even application, especially if you're applying it to your own head (since it takes longer to do generally speaking).
You can work in sections to preserve color and get a more even application. Simply mix enough color for one section at at time, apply and process, then rinse ONLY that section with water to stop the chemical process. Repeat on all other sections. Good luck!
Mar 27, 2011 | Goldwell Topchic Effects Highlight Color 2...
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    Need eyeshadow advice?? I've never been good at applying eyeshadow. I never know if I should cover my whole eyelid or what color to use. And when I do where some, it seems to always get smudgy by the end...
    My advice is to stick with something natural at first. I like eyeshadows with a little bit of shimmer... they just stay on better with me! For everyday, I like a shimmery peach or taupe and I apply them on my lid up to the crease. Then I use a shade a little darker in the crease (you can skip this part if you want something simpler). You may want to play around with colors to see what you like best with your coloring.
    Another tip... applying concealer and powder FIRST helps my eyeshadow have something to stick to. If I apply it with no makeup on before, it doesn't last as well. I also apply eyeliner and mascara after the eyeshadow.
    Just have fun with it! Try to stick to lighter colors, so if it does smudge, it's not a big deal!
    Punch Professional Home Design Platinum Suite (26635) Logo
    191 people viewed this question
    Top Punch Computers & Internet Experts
    Lawrence Oravetz
    NOEL
    NOEL
    Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
