Question about RCA HD52W59 HDTV Projection Television
Rca hd52w67 w/irc222 chassis
My convergence is out of whack. i no longer have the convergence option on my tv. it was built in april 2006, sound is good, picture is in triplicate. i am at my wits end trying to get help with this. i dont know the proper name for this board and cannot find the part #, could u please give me a company who actually carries this item. any solutions u may have with this convergence problem would be awesome. anything i can do at home?
  • cshaunc Jun 17, 2008
    I'm having a similar problem. Except my convergence works fine in dvi
    mode ,but when I go to other inputs such as vid 1,vid2, and front
    inputs. The convergence is out of whack and I can't get it
    realigned.But when I use the cmp1 which I use for xbox the cmpi
    letterbox is out of wack but when I turn the xbox on its clear as day.
    I'm at a loss. Any Help would be great.
    Genius:
  • 1,030 Answers
If in setup the convergence option is missing then more than likely a special fuse fl231 has blown... this is caused by bad solder connections on the part known as the flyback... if you can solder and get the fuse then this could be a simple fix
Posted on Jun 10, 2008
I'm having a similar problem. Except my convergence works fine in dvi mode ,but when I go to other inputs such as vid 1,vid2, and front inputs. The convergence is out of whack and I can't get it realigned.But when I use the cmp1 which I use for xbox the cmpi letterbox is out of wack but when I turn the xbox on its clear as day. I'm at a loss. Any Help would be great.
Posted on Jun 17, 2008
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
HD52W67 RCA YR.2005 The picture is concaved the color is shifted slightly to one side. When I went to menu convergence it shut tv off then came back on without the convergence menu there. I was told to...
Look on the board next to the flyback you will see three small brown plastic rectangles. Those are fuses the center one is FL231 that fuse and possibly diode D231 and capacitor C231 is blown thats why the convergence option is no longer on the menu. If you need more info please respond to this sme post so I have access to the info again.
Jun 26, 2008 | Televison & Video
Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Televison & Video
Convergence
Okay, usually the parts that go bad to make the convergence option drop from the menu are the following. Fusible Link (FL1231) Diode (DP1231) and capacitor ( C1230) the numbers in parenthesis are the actual component locations on the board. These items fail causing the set to think its a direct view set instead of a projection unit.
RED GREEN BLUE CONVERGENCE IS OUT.
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
Jan 08, 2008 | RCA P52926 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
