Question about Whirlpool Dryers
We have a Whirlpool dryer. The strip of sealant is peeling off the inside back of the dryer. Does it need to be replaced, and if yes, how.
    Genius:
  • 1,028 Answers
Yes or else you may rust stains or torn clothing ..remove dryer front and pull tub out cut seal off and install new seal may a task not for the weak of heart can be a dog for unexperienced
Posted on Jun 02, 2008
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
The whirlpool dryer I have is loosing its sealant strip on the inside of the back of the dryer. Does it need to be replaced and if yes how.
yes..it may lead to some kind of water or heat leakage..
you could call for a technician o that company..
they ll do it for you
Jun 01, 2008 | Whirlpool Dryers
Paint of dryer inside peeling off
yes request to the landlord to replace it
Mar 15, 2014 | GE Dryers
I have a whirlpool RM278BXS microwave oven. Inside the microwave oven along the rear bottom is a thin strip of sealant. The sealant is melted/burned in the middle section for about 1-inch long. I can...
Your best bet is to pull out all the old seal you can, and to trim what's firm with a razor blade.
Sand it smooth if necessary, then clean it squeaky and apply new caulk / silicone sealant.
Leave the door open to allow it to dry out overnight.
If it's not repaired, moisture can cause rust, which will lead eventually disintegrate the metal and lead to to arcing and possible fire in time.
Jun 07, 2012 | Whirlpool Microwave Ovens
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Dryer works but has no heat. Voltage is good. Could it be the TCO?
    I suspect that your heater strips in the dryer have burned out. Just to give you an idea, I have replaced my heater strips in my 40+ year Whirlpool dryer two additional times over the years. You will have to take the back off of the dryer after disconnection the 220V plug and examine the heater strips.
    Nov 30, 2010 | Roper Dryers
    The lacquer on the front wing of my car is peeling. Is there a diy fix
    Sorry to say it but in most cases it needs to be repainted. If you want to try you can lightly sand it and reclear coat it, but if the base coat is causeint it to peal then it needs to be sanded and sealed with a good primer/sealer and repainted.
    May 09, 2010 | 1994 Jaguar Xj Series
    Need to repaint bubbled and peeling paint on top of dryer
    The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
    If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
    Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
    Dryer is leaving brown marks on items
    Yes, this is what causes the brown marks, the felt piece will have to be replaced.
    Apr 11, 2009 | Whirlpool Dryers
    Whirlpool stacked washer dryer LTE 5243DQ6
    Open dryer door, and reach up to the top of drum and push on it very gently. If it moves more than 1/4 inch or more, the dryer guides needs to be replaced. Sadly the guides are for front and rear so that means the drum has to be removed and the guides in the rear has to be changed first.
    It will involve some time so be very careful! Another thing is to check for the dryer idler arm pully. if this pully is squealing/worn out, it will also need to be replaced at the same time you replace the guides.
    My suggestion is to call your contractor and make them come out to see if they damaged it. Your local appliance repair store can also sometimes help.
    May 16, 2008 | Whirlpool LTE5243D Top Load Stacked...
    Dryers Logo
    76 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
