Question about Soyo DYLT032D 32 in. LCD Television
Wont come on .getting worse starter prob i think takes 10 min to come on now wont even start after 1 hr ..lite on front goes from red to yellow to green then repeats
  • 998 Answers
It has a problem in the power supply it is the common problem of the lcd try check the power supply you might see a visible defective parts then try to replace it
Posted on Oct 13, 2010
What are the ignition switch connections on a bobcat 720? The manual gives me the wire colors, but the connections are too blurry to accurately tell what wire goes to which terminal. It is a 4 termina
it requires 3 wires to start 2 to feed power to ignition and 1 to acativate starter , signal wire ,if you use a test light and find power and make up 2 sets of jumper wires once you touch the red wire to any 1 wire you should hear starter ingauge but it wont stay running till you connect yellow and black wire , once you know what wires do what its easy. that's the way I remember it im sorry if this is confusing if I was there it would take 5 min.
Oct 25, 2014 | Cars & Trucks
During play yellow lite comes on where green lite is and station shuts down even on internet play wont stay on for more than 3 minutes or so..
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. (now it comes back on, eventually it won't) This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Car wont start when warm
Sounds like the timing is off and valves need adjustments.
Feb 03, 2010 | 1995 Volkswagen Golf
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Wf840 f10 error code get worse
F10 is indicating 2 possible probs with your m/c.
1-interrmittent cold water supply, check pressure and hose.
2-water level switch not sensing correctly, possibly sticking or partially blocked.
Hotpoint recommend calling an engineer for a pressure switch prob. but there callout is £90.00!!!!!.
Plz rate my solution.
.Thanks
Dec 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
Theft system 2000 malibu ls
try this: turn key on, crank starter for 1 second, leave key on for 10 minutes. after 10 min. shut key off and repeat 3 times. (on second try, crank a sec. or so longer, the reprogram may take off right away. if not, repeat make sure battery is strong, key could be on for 1/2 hr. sometimes engaging emergency brake before key is turned on prevent daytime running lites to come on to save battery power (if equipped). been through it, thought i'd mention it
Nov 16, 2008 | 2000 Chevrolet Malibu
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Soyo DYLT032D 32 in. LCD Television Logo
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
